Dsmall2112
- USA
Attn
I didn't know about the various types of cadence sensor technology, so thanks for that. Too late for me to get a torque PAS, which sounds like it might have been smoother.
			Craig - was glad to find this thread, so thank you. I too was interested in responses given my recent purchase of ebike Magnum Premium II (with CS6 LCD display controller).Can the ebikes like (Magnum) be toned down when it comes to initial acceleration ?
I test rode one, and at the slightest start off, I popped a wheely !
As well as making a tight 360 degree slow turn around, it lurched me around that turn.
Can the control of bikes like this be Tamed ?
Craig
- I have tried the "Eco" mode option but that didn't really help with the initial "surge".
- What I have since learned (trial and error) that the throttle (lever) on my bike has much smoother acceleration curve than PAS. So (as newbie) from stopped position (or when I need smoother acceleration or "lower speed power") I use throttle to get going first, then begin pedaling to engage PAS once I'm ready.
- (Not Tested) On my bike, there is a "max speed" setting for the throttle (4 options: 0, 3.7, 12.5, 20 mph) so I have set throttle to 3.7 max MPH. Haven't tested this yet, but hoping the throttle will max out at 3.7 smoothly (ie uniformly over the lever's range) to avoid that "initial surge". Once tested I will reply to forum with results.
- I will undo these options once I'm comfortable, but I wanted to share in case this helps anyone. BUT if I ever let someone a test ride (with no PAS experience) I'll advise to use throttle first (and may limit the throttle 3.7 max MPH settings).
