I now realize why "Amateur Cyclists", like myself, have a hard time relating to eBikes. The power assist levels make no sense to an experienced cyclist. Power assist levels need to be communicated to advanced cyclists in terms of riding style. Presenting power assist levels in engineering terms to traditional cyclists is meaningless.
The aim of cyclists is to maintain momentum, rather than to achieve an arbitrary speed limit of 20 or 28 mph. Wind resistance is a natural speed limit, that becomes a serious hinderance about 25mph. Acceleration is key to maintaining momentum. Momentum can be quickly lost on moderate grades. Momentum can only be gradually increased on flat sections through skilled cadence, torque and gear shifting techniques. Once 15mph is reached, 25mph is less of a challenge to overcome, due to momentum. An acceleration-oriented electrical system addresses the needs of an amateur cyclist.
Standing up to accelerate, or getting low in the drop bars to avoid wind are riding styles that traditional cyclists can relate to. The benefits are immediately clear. Conventional ways of defining and communicating power assist levels are a sure way to end any interest in an eBike. Silly.
The motor response should feel like sprinting, rather than a 800m pace.
Some advanced cyclists can generate more power than a common eBike motor, so what is the point of emphasizing power levels? Silly.
More conspicuous is the protuding battery and oversized chain ring/bottom bracket. The look and feel is wrong: they look plain ugly and feel too heavy.
A Red Bull article does a good job at listing current options, but none are acceptable to me: 10 E-road bikes that are almost too good to be true.
Let's associate symbols with a rating scale from -3 to +3, to discuss the merits of certain eBike features.
Weight, Shape and Gearing of Motor for Acceleration (2.3 kg)
Weight and Shape of Battery (2 kg)
Accurate and Responsive Sensors for Acceleration
Now we have a framework to compare two bikes. We can compare two ultra light electric road bikes, conventional bikes or any combination.
Since the Maserati Trofeo is a true hybrid road bike design, let's use the Maserati Trofeo as a baseline eBike. The Trofeo is a concept bike, not a stocked item in production. The Bafang M800 motor and a carbon frame for the M800. My local Velofix mechanic feels he can build the bike for me.
Notice how the battery and motor are barely noticeable in the downtube and bottom bracket area? A very elegant design that pleases.
- -3
- -2
- -1
- 0
- +1
- +2
- +3
Stand-up Pedaling Assist ( "eSprint mode", like "eMTB mode" for Bosch mountain bikes)
Acceleration from 0 to 15 mph in a middle gear, on the inner chainring
Speed
Miserly Battery Consumption
Distance
Power and Sensing to Fight Strong Winds (opposite of standing up, I get low into dropbars, even at slow speeds)
- A torque sensor for each side of the bottom bracket.
- Two or more speed sensors on wheel
- An accelerometer
No Resistance From Electrical System
- Desired: +3
- I want to reach conventional bike speeds, without hitting a speed wall induced by motor gearing
- Desired: +3
- I stand up at least once per uphill mile. Stand-up pedaling slows me down and wears me out. Standing up avoids downshifting gears. I climb the hill faster, but I am out of breath and weak when I reach the top of the hill. Recovery usually takes a few minutes, so my speed is very slow, e.g., ~10mph.
- One torque sensor for each pedal might be an advantage in this situation.
- Desired: +3
- Mostly for crossing big intersections in the middle gear on the first chainring.
- Two or more speed sensors for accurate and sensitive acceleration measurements (or accelerometer)
Speed
- Desired: -2
- I do not want high speeds because they drain the battery
Configuring Power/Torque Curve from cell phone in a user friendly way
- Desired +2
- I want a UI to specify parameter values for when and how much power assistance should be applied
- Desired: +3
- Desired: +3
Electrical System designed for carbon frames
- Aluminum is too heavy and does not flex to absorb shocks
- Desirablility: +3
- Desired: +3
- I only want the motor to deliver power assist at critical moments.
- I want the motor to disappear on the flats and downhill sections, so I can travel long distances.
- I want strong assist at the critical moments.
- For the most part, I want the electrical system to blend in with the bike and disappear as part of the cycling experience.
Bluetooth Motor and Battery Management System
- Desired: +3
- Need to know when to avoid using due to weather conditions.
- Need health status of every battery cell.
- Need to update firmware via internet.
- Need to run diagnostics against battery to know how risky a cold weather ride is.
Fighting Strong Winds (opposite of standing up, I get into dropbars, even at slow speeds)
12v Front and Rear light system
- Desired: +3
- I ride through at least five tunnels and/or bridge underpasses. The C470 tunnel is 425 feet long. I cannot see mud or ice at the other end of the tunnel. I need a very powerful light with high and low beams. I want a rear light to alert other riders in the tunnel of my presence.
Cold Temperature Range
- Desired: +2
- My biggest fear is an undervoltage that shuts down the engine from electrical resistance at cold temperatures.
Distance
- Desired: +2
- 60 miles per battery charge is adequate
Cost
- Desired: -2
- I do not expect low cost or want to sacrifice quality.
- Reliability is important.
Traction
- Desired: +2
- Wet or muddy conditions require wider tires. Also power assistance needs to be applied in a gradual manner to avoid sliding out. Inner rim width is main influence on contact patch shape.
Braking Power
- Desired: +2
- Wet conditions need larger hydraulic disc brakes (180mm)
Nible Steering
- Desired: +2
Tubeless Tires
- Desired: +3
- Flat tires in cold weather is a total drag
Gear Ratio
- Desired: +3
- Need 400% on a double chain ring
Aerodynamics
- Desired: +3
- Need dropbars to reach 35mph easily.
- Motor and battery cannot introduce drag.
Aesthetics
- Desired: +2
- A bike should look beautiful, not like some car parts were glommed onto the frame.
Boost Axle
- Desired: +1
- A good rider can put out 800 watts. The total acceleration force may be very high.
- Need strong rims.
Removeable Battery
- Desired: +3
- Need to bring battery inside for charging.
Display motor and human power in watts.
