A few Hydra pics
Can you imagine that thing with an Archon x1?
The frame isn't as sexy as the Hydra, but it is impressive that they've managed to get that much voltage integrated into the frame.
I think I remember hearing something like 240nm peak? I'll have to dig. Although, that advertisement is only mentioning the standard 160 nm for the bafang. I'm sure it's higher with their changes to the electrical system.
Also, I'm pretty sure the real limiting factor on NM right now is the hub/chain.
Here we are...
It definitely is.
If you need to go above that 2500W, you need to consider dual drive train like the LMX 64 (3,000W) or the SEM Venom (4,000W), or the Boxxbike Valkyrie (12,000W).
I squeezed 70x 21700 cells in mine.
Nice !!
Which cells if I may?
EDIT:
never mind, I can see in the picture they are Molicel P42A
that means a 14S-5P pack for 50.4V x 21 Ah = 1058Wh
Peak 225Amps x 50.4V = 11.3kW Possible peak power, way above the max the motor needs
Nice!
Not sure what you are talking about. Looks just like the Hydra frame, other than the reinforcement for the rear shock. AFAIK there isn't room to install a dual battery on the Hydra so no loss there. The tires, shocks, etc. pictured are just window dressing, could put the same on the Hydra frame or vice-versa.
I’m pretty sure it is, asked Dengfu about it and they indicated it was theirs, guessing to work around ‘exclusives’ for both E10 and E22 frames..
