2022 Rize RX "virtual teardown"
wanders
Austin TX
I recently got a 2022 Rize RX, which I really like. I decided to do a "virtual teardown" of the bike to facilitate repair, replacement or upgrades to the bike. I wanted to publish the complete specs of the RX so that other owners or prospective buyers might benefit. There may be errors herein, so I encourage any authoritative corrections. I'll give details regarding the components of the bike, but I'll not focus on the Bafang motor and controls, which have been covered ad nauseam elsewhere.
TIRES
  • Kenda K1015 Nevegal-X Sport 27.5x2.35 (650x58B), marked 30-50 PSI
  • OEM style tires with "KENDA TIRE.com" marking
  • NB: in the photo below, I have replaced these with Goodyear Transit Tour 27.5x2.0 S3 tires (commuter tires)
WHEELS
  • unbranded hubs and (painted) rims, 36h, straight-gauge 2.3mm (13ga) spokes with 3.7 mm nipple sizing (no Park spoke wrench will fit)
  • front hub: 100x9mm quick-release with pressed-in sealed bearings, captive axle, screw-on locknut-style endcaps
  • rear hub: 141x10mm BOOST-spacing bolt-on with threaded-on hyperglide-compatible freehub, pressed-in sealed bearings, captive axle
    NB: this spacing is not compatible with 142mm hub
FRAME
  • sturdy aluminum
  • nicely painted
  • uninspiring but functional welding
  • custom bolt-on aluminum rear rack (16mm+ main tubing, 10mm+ secondary rack size)
  • 141mm rear vertical dropout
  • untapered head tube
  • derailleur guard bolt-on
  • braze-ons for auxiliary battery and water bottle
  • unbranded but well-made plastic mudguards (fenders) with custom-fitted stays
  • see my other Rize RX post for the geometry
COMPONENTS
DRIVETRAIN
  • Bafang M620 CAN-BUS mid-drive motor with gearshift sensor, brake cut-off, 170mm crankarms and 44t chainwheel
  • Bafang DP-C18 CAN-BUS display, non-ECO/Sport model, with button control and throttle
  • Shimano Acera or Alivio 9-speed derailleur and shifter (depends upon which part of the 2022 model year run you have)
  • Shimano Alivio HG CS-HG400-9 11-13-15-17-20-23-26-30-34 Hyperglide cassette, all steel cogs
  • shift sensor (probably gearsensor.com's GS model) buried in the battery compartment
BATTERY
  • Zhejiang Tianhong Lithium-Ion Battery Co. Ltd. Model IR-7-U; 14s3p pack comprising:
  • nominal voltage: 51.8V, max voltage: 58.8, max discharge current: 44.1 amps
  • see the Zhejiang Tianhong Lithium-Ion Battery Co. Ltd facebook page for more information on this pack
  • note that this case is almost certainly too narrow to configure the 21700 cells in a normal lateral array, so the cells are probably oriented longitudinally (unverified)
  • direct sourcing this battery pack might be problematic due to variations in wiring and charging socket
OTHER NOTES
I really like this bike a lot, although I think the wheels are a little funky; I'll probably build new wheels with a 141mm BOOST rear hub at some point. The bike rides nicely and handles well, and is outfitted very reasonably at its price point, which is very moderate for an M620-powered ebike. I'll also be adding a bright flashing tail light for day use.
Here's my bike, set up for urban riding:
One thing I did not like in the original "cockpit" was that the left and right brake levers were not aligned identically, The right lever was butted up to the grip, which gives a natural reach to the lever:
while the left lever was offset by the width of the throttle clamp:
I reoriented this so that left and right levers had the same orientation to the grip. I consider this a (minor) safety issue:
and my thumb is long enough to reach the throttle and controller, so no issues there, except I almost never use the throttle.
Next task: get the cabling in the cockpit cleaned up.
Willie
Nice write up. The only thing I wanted to add was handlebar orientation of "stuff" is pretty easily handled for each owners personal tastes. For instance (with the fact my hands are generally accepted as huge in mind) on my right hand side, I have the shifter next to the hand grip, followed by the throttle (which is not used often), then the brake (which has generally 2 fingers on it at all times). No right/wrong here in my mind, but my justification for a RH throttle is the last 50 or 60 years of my life have been spent with any type of hand throttled toy has had the throttle located there - starting with my first mini bike at about 10 years old.... FWIW, -Al
