arnold ziffle
Thanks for the tech ... question, sir ... upgrading the 2018-2019 R750 rear shock ...
you were able to fit a 190mm DNM where a 165mm A5 was simply by lifting the
fronts of the brackets to increase the spread? Does the bike sit slightly higher?
Does your shock pump require you to dis-assemble the top shock brackets to
attach the zirc? (my FOX does, PIA).
Also --- regarding controller param. #8, CUL ---- have you tried 19, per the
voltbike 750 1000 Watt DIY ?
Also ---- wanna see ebike bear tracking? Snake wrangling? yt "advancing angling"
Thank you sir .....
Thank you sir .....
