2015Kalkhoff
I have a 2014/2015 Kalkhoff with a broken impulse 1 motor. Although getting an expensive new motor from Kalkhoff is an option, I don't think it is a good idea, considering the well-known issues with this motor (and also impulse 2). I am thinking of modifying the frame so that a better motor can be added, while keeping the same battery. I would make this by hand if I would do it for myself only, but if there is a demand for a bolt-on kit, I can come with a more elegant solution. This will require designing, machining, welding, etc and addition of a strong Chinese motor so that the product is a motor that can be simply bolted on. New controls will be added on the handlebar (while keeping the same battery).
I was wondering how many old Kalkhoffs are out there with a bad motor and if anyone is interested in purchasing a kit. How much would you spend on making your Kalkhoff bike work or is it not worth fixing it. I think these are well-built bikes with a poorly designed motor. I have read some posts about riders asking if it is possible to upgrade using a Bosch motor but I think it is not straightforward, plus it is a more expensive solution. Please correct me if I am mistaken.
Also, do you know if the bolt pattern on the frame was different for impulse 2? Local bike shop said impulse 2 cannot be installed on the frame with impulse 1 but I am not sure about that. I am in the San Francisco Bay Area.
Thanks!
Thanks!
