2021 Turbo Creo SL Expert EVO - 3 month review
Re Di2 on Creo, I use the Shimano XT MT800 display. This shows which gear you are in and also doubles as both the junction box and a wireless Bluetooth / ANT+ unit. I love that it show what gear you are in and battery levels and make a nice neat cockpit look. Note that it can only mount on the right side, which can be an issue with some Garmin mounts. I mount my Garmin using the front mounted stem attachment, but the original Garmin mounts do attach on the left.
Yep, the color is unbelievable, it’s blue till the sun hits it and then it goes almost a luminous green or teal. Very snappy!
And thanks, Stefan! I only got time for a quick shakedown today before the rain showed up, but tomorrow I should be able to really go out and make friends with it.
So is this plug-n-play? Do I need to install any additional Shimano unit for my Creo Expert EVO?
Yes. It replaces the junction A box and has 3 ports on the back. Just swap your existing junction A for this one and it works right off. You can go into Shimano E-Tube and customise the display if if like. Wireless on it worked right out the box for me to.
