If you have a 2016 Turbo X, you can load Mission Conteol on an Android or IOS Smartphone and cheeck the battery firmware version yourself.
I called Specialized Rider Support. It took a while, but I found out that the battery and motor firmware on my bike are current. By the way, I ALWAYS charge my battery off of the bike. Could that affect why my odometer has NOT reset ever?
I'm bumping into a lack of clear understanding of how the cadence vs torque sensing works in daily usage, specifically on the Turbos. Maybe one of you fine folks can help me out.
On my cadence sensing eJoe Koda, we've got assist 1 which gives a little boost till about 10mph. Assist 2 a bit stronger kick, goes till about 15mph; 3 dials it up again till about 19, and 4 gives you a lot of kick across the spectrum. There ain't a lot of variation, the boost is what it is within each level. So I can ride along on flats easily without any assist at maybe 14 - 15 mph, and when the hill appears, punch the Plus button to the assist I want to get over it. I've found that if you're use patient enough, you can get over some impressive inclines even at level 2, as long as you're in a low enough gear and just keep the pedals turning over as smoothly as possible.
So here come all you guys talking about riding at Eco 50, or 60, or whatever, and it sounds like a different and interesting world. So do you just leave a Turbo on whatever setting you've dialed in (except maybe for full turbo assist, I sort of get that) and the torque sensing feeds you what you need? I've never had the opportunity to try A Turbo or any torque sensing bike, but after reading all the threads about the bike, have been feeling that one of these might be my next stop in the ebike world. Of course, now it seems like Specialized is moving to mid drives, so if true that may add some urgency to any decision. From all my following the dedicated Turbo fans here, they sound terrific. I love the fact that they have the whole Specialized name standing behind them as well.
Just to second this...the ECO levels allow you to dial in a linear amount of assistance. Thus ECO50 provides about 1/2 the assistance of full TURBO. It also allows me to go about twice the distance. The e-assistance is provided across the entire speed range, however.You pretty much have the understanding down. It doesn't matter how fast you are pedaling but how hard. Also the assist is not dependent on speed till you hit the limit at 27mph/44kph or so for USA bikes or 16mph/25kph for euro specd bikes. Best thing to do is try one at your local dealer...just a warning, you're gonna want one![]()
Hey Dave- Glad you are checking out the Turbo. I just got an X and am very happy with it so far (only about 2 weeks and 160 miles).
To add to what the others said, I don't think it impacts where the assist cuts out (max speed), just the strength of it. I'm still figuring it out for myself because sometimes I'll be cruising with pretty decent effort at 24 mph in Eco60 and then I'll switch to Turbo with no apparent impact (I'm still working just as hard and my speed is exactly the same). It seems like in that case the motor was already putting out max power in Eco60 and doesn't have any more to give. That would imply that any Eco setting can actually max out the motor and the difference between Turbo and Eco is simply how much your power is amplified (subject to max power).
Anyone have thoughts on that?
