onlineaddy
Unknown Member
- USA
- City
- San Diego, CA, USA
Will have to stick with the original CrossCore for the lighter weight: 43.5lb (M)CrossCore RC (S–L, weighing 52.2 to 52.6 pounds) ; Ouch ! , ... was hoping for lighter .![]()
They will both be available this summer .
Among other things a suspension forkWhere does the weight gain come from though?
That's my suspicion as well.So I guess the Wabash and CrossCore have identical frame?
Wabash RT - L: 46.7 M: 46.4, S: 46.2 (lbs.)Will have to stick with the original CrossCore for the lighter weight: 43.5lb (M)
If that's the case , I would consider swapping the drops for flats .So I guess the Wabash and CrossCore have identical frame?
I was complaining of the weight? Where do you see that?You were complaining the new CrossCore is nearly 10 lbs heavier.
The difference between rigid fork and suspension fork can't be 10 lbs..
Also, if I'm not wrong, the new motor is 100 gram (0.22 lb) lighter than previous CrossCore.
No worries. I have no personal stake in these bikes. Just reporting and sharing info.Sorry I didn't meant to be aggressive at all. My apologies if I seemed that way.
I don't know if you were complaining or disappointed, a little difficult to see the situation over forum.
This one looks very tempting and can't wait until it comes out and reviewed."We're about to unveil two new E-Bikes that will propel the industry forward, offering unprecedented levels of power, poise, and responsiveness."
but not seeing anything in the specs that is different or better than any one of a dozen offerings from other companies.
You can shave off 5+ lbs from wheels, tires and suspension -> rigid.Will have to stick with the original CrossCore for the lighter weight: 43.5lb (M)
Needs hydraulic brakesI like the simplicity .
Crosscore RC uses 27.5 x 2.0 . Current model Crosscore uses 700c .
https://www.yamaha-motor.co.jp/pas/ypj/crosscore-rc/
https://www.yamaha-motor.co.jp/pas/ypj/wabash-rt/
