Want to be able to get around with my five year old- towing him on a wheehoo or trail-a-bike. I am 5'6" and have a just over 30" inseam- Ideally I'll have a bike we can also use to cruise the local rail trail. I am wondering about step-thru models and their ability to deal with towing...
A refurbished Juiced ODK U500 is $1200 and offers nearly 900 watts peak power, low step, smaller 20" tires, cruise control, long range, hydraulic disk brakes, lots of bolt on accessories including a huge sturdy front basket, and a
dealer network so you can take a test ride before you buy. Check out
Court's review. Here's a
review by a parent. Here are some
first impressions from parents in hilly Seattle, they recommend adding a wide double kickstand like the
Ursus Jumbo but check with Juiced if they will fit one or what they suggest would work.
Two Wheeling Tots has a buying guide on trailer cycles, one consideration is to check the measurements of the trailer cycle arm to make sure it will clear the extra long rear rack of the Juiced ODK, you might want to ask Juiced what they suggest might work - you might need some sort of extension piece or a trailer cycle arm that bolts onto the rack rather than the seat post. Or skip the trailer cycle and get rack mounted
bars, seat pad, and foot pegs/boards for a passenger. One issue is the ODK uses
Kenda K-924 tires that are not standard bicycle tires but use a harder rubber compound which makes them stiff and difficult to get off the wheel rim in the event of a puncture, you could either swap them out for something more puncture resistant like the Schwalbe Big Ben Plus tires, or buy some
Park Tool steel tire levers and have a plan B e.g. a cell phone with GPS and if you are a member of AAA and you can push the bike to a road they can arrange for a tow truck to take you and your bike home.
