48v battery for front rack
mohammed
United Kingdom
Hello all,
I hope you've all been well.
I bought a Pedibal Maxima (https://pedibal.com/products/pedibal-maxima-fat-tyre-folding-cargo-electric-bike) non fold version about a year ago but now thinking about some mods.
I wanted to attached another battery (range anxiety) but there isn't many ways to do it.
The seat tube is too short for a downtube battery and i want to avoid putting one on the rear rack so i was thinking about putting one on the front rack, a bit like how the Brompton ebikes have it.
What do you think? Will there be any issues? Can you recommend a battery, maybe one of those pvc ones?
I'm not looking for like 40ah, 14-25ah will be fine.
Using 21700 cells, it's 39 cells for 15 AH, and 65 cells for 25 AH. Figure 70g per cell, That's 6 to 10 lbs for the cells. Add another 3-4 pounds for a Hailong case. So it's 9 -14 pounds of weight with a case that is 16 inches long. They claim 5Kg or 11 pound payload on your rack, but it's going to look ugly,
As for PVC wrap batteries from China, they're likely to be firehazards. Used to be guys in the UK that could build you a safe custom rectangular battery to fit your rack, but I think liability risks drove them out of business.
mohammed harryS covered the size and weight, so the bit nobody's mentioned is how the second pack connects. Simplest and safest is to just carry it and swap the plug when the first runs low. If you want both connected, don't simply wire them in parallel: packs at different charge push current into each other, and Battery University says paralleled packs should match in voltage and capacity. A dual-battery switch, or a diode/ideal-diode combiner so neither pack can back-feed the other, is the usual way to do it.
Either way the second pack should have the same series count as your 48 V LG pack, a BMS that can supply the controller's maximum current, and the same connector. Charge each pack on its own, never left linked. On the rack, keep it low and strapped, and give the cable a loose path past the head tube so steering can't pinch it. And I'd go with a hard-case pack like harryS said.
This is what I was thinking to do. I actually just mounted a Hailong type battery to the seat tube instead. I will leave this for later.
