What do you check first before choosing an e-bike conversion kit?
JL0256
I've been looking at different e-bike conversion setups lately, and the more I read, the more it seems like choosing a kit based mainly on motor wattage is probably the wrong way to go about it.
At first it's easy to look at 500W, 750W, 1000W, etc. and assume that's the main decision. But after reading through some builds here, there seem to be quite a few things that can cause problems even when the motor itself looks right.
A few things I'm wondering about:
  • Hub motor vs mid-drive — For a fairly normal bike, what usually makes you choose one over the other? Is it mostly terrain and climbing, or are reliability and maintenance just as important?
  • Fitment — With mid-drives there's bottom bracket width and clearance, while hub kits bring up dropout width, wheel size and axle fit. Which measurements do you always check before ordering?
  • Battery and controller matching — Besides making sure the voltage is compatible, how much attention do you pay to controller current and what the battery can actually supply?
  • Brakes and drivetrain — At what power level do you start thinking seriously about upgrading brakes, chain, cassette, torque arms, etc.?
  • Parts availability — This one seems easy to overlook. If a display, controller, cable or sensor fails a couple of years later, being able to buy individual replacement parts seems pretty important.
  • Installation difficulty — Are there certain types of kits you would recommend avoiding for a first conversion simply because they tend to create more compatibility headaches?
I'm not trying to build the fastest bike possible. I'm more interested in what makes a conversion reliable and relatively easy to live with after the initial installation.
For those of you who have done several conversions, what are the first 3–5 things you check before buying a kit?
And what's something you learned the hard way on an earlier build that you now always check beforehand?
Bafangs are heavy and bullet proof, but there are issues with newer mid drives using locked battery tech..give them a wide berth.
I've done geared hubmotors front/rear plus mid drives. I've also purchased a few inexpensive but decent ebikes. Been ebiking for 11 years. It was originally cheaper to build/convert but today, if you watch for closeouts, you can often buy a better featured ebike for less than the price of converting something,
What's the purpose for converting a bike? Is it for sentimental reasons on a beloved bike, or to build something not readily available? I've converted clunkers/junkers and spent time/money upgrading them. Maybe don't be doing that. After we get past the why of conversion, then we can go thru the details of how to convert. I'll give my answers to your specific questions next,
Originally, it was price. A Bafang BBS02B was over $500. The CYC's twice as expensive. Hubmotor kits with wheels were selling for $250 ten years ago. More recently, pricing is closer. I personally think a mid drive is easier to install, as there is no controller to locate and wire up. I also think a torque sense mid drive kit is hard to beat in the class II realm. More fun to pedal and it has a throttle.
You might have a newer model bike with different style BB, but the majority of older bikes are 68mm with square taper BB. Most newer bikes have 135mm rear and 100mm front drop outs. Fat tire bikes are 175mm rear, 135mm front. . Older steel 10 speeds are 120mm, but only a few diehards like me convert them.
It matters for higher power builds, but most of my hubmotor bikes are 20A or 25A controllers. It's pretty easy to get a battery rated to supply 25A. My BBS02B middrive pulls 25A peak, while my various mid drive bikes are 12-13A peak. A 25A battery would be fine there. If you;re building a +30 mph bike, you'e spending a lot of money on a battery. I never need to power up past 20 mph, unless it's a bragging rights test. Once I know the top speed, no need to check again. Most of my my riding average 12 mph, I only have two bikes that an exceed 25 mph on throttle.
I have always installed torque arms on every hubmotor build. I have noted that my commercial ebikes with hubmotors didn't have torque arms. When I can, I use a torque wrench on the axle nuts - 25 foot-pounds. I mark the nuts too, and have never seen any move,
Have never broken a chain. I use KMC standard 7 speed chains. Think their ebike rated chains are likely the same chain. The Bafang BBS02B will cause stretched chains and old freewheels to pop and skip. so those get replaced on a comversion. I'm still using a 40 year old chain on my DM02 mid drive since it's not making any noises and doesn't miss a shift,
You want good brakes, regardless of power, but for a Class 2 that rarely goes over 20 mph, caliper brakes work. If the hardware/fittings are there. I'll change a wheel to disks. Gets expensive to replace w caliper wheel hub with a disk brake wheel though. Its just for looks.
You forgot wheels. Nothing makes a bike more sluggish than steel rims. Don't get a donor bike with them. It will cost $150 to swap, and you really had to love your old beater bike to do that.
Parts availabilityThis one seems easy to overlook. If a display, controller, cable or sensor fails a couple of years later, being able to buy individual replacement parts seems pretty important.
In the DIY world, if you stay with popular kits, the parts are available. For example. Bafang no longer sells the uart based BBS02, BBSHD middrives, but you can still buy the controller boards. Same with displays. That won't be forever though, but I don't plan to buy any spares. On the other hand, I liked the way the Tong Sheng TSDZ2B middrive ran with aftermarket firmware on our bikes that I bought a spare motor kit when they were on sale for $240, even though you can buy almost all of the intern parts ala carte,.
Newbies often do front drive hubmotors because they fear the unknowns of adjusting a derailleur for a rear hubmotor. First, this task is something any DIY bike enthusiast should know. Next, newbie errors are more likely to let the front motor spin out of the fork and faceplant the rider. I'd rather see the newbie do a rear motor.
Mid motors have the same issue. You need more tools, like a chain breaker to remove the chain, tools to take out the BB, and the dreaded readjustment of the derailleur. But there is no controller to locate on the frame, and no need to put it in a box where it can get wet. I'll spend several hours planning how I will fit a box to a bike and putting a controller inside it.
Mid drives make better use of the motor/gearing and you can run them on smaller batteries.
I think that if you take on the job of converting a bike to electric, you need to be able to handle all aspects pf bike maintenance, You should be able to adjust your handlebars and grease the head set. Even a hubmotor should have the BB looked at and regreased.
That's a good point — I hadn't really thought about locked battery systems as part of the buying decision. I can see how that could become a problem a few years down the road if the original battery becomes difficult or expensive to replace.
Thanks for taking the time to go through all of that — there’s a lot there I hadn’t considered.
Your point about asking why someone wants to convert the bike in the first place probably stands out the most. I was thinking mainly in terms of choosing the right kit, but it makes sense that sometimes the better decision might simply be buying a complete e-bike rather than putting money into an older donor bike.
The parts availability point also makes a lot of sense. A kit that looks good initially could become frustrating if a controller, display or other part is difficult to replace a few years later.
If someone already had a decent donor bike and the goal was just a reliable commuter around 20 mph rather than maximum performance, would you personally lean toward a rear hub motor or a mid-drive today?
Torque sensing mid-drive. 500W nominal.
That’s interesting. Is the main reason you prefer it the more natural riding feel, or do you find it better for everyday reliability as well?
And do you feel 500W nominal is about the sweet spot for a normal commuter build?
Her bike although rated and stamped at 500W is capable of 20Amps on a 48V nominal battery. I took down the maximum amps to 18 for safety and set the temp sensor to go into limp mode 30% at 100C. Scroll down to 'A bike that doesn't exist'. 18x48=864W. https://substack.com/@pedalingeast?r=2jrs0&utm_medium=ios&utm_source=stories&shareImageVariant=light. You can also see local reviews of these converted bikes on Google Maps, PedalUma eBikes. And watch the conversion process with peer review here. https://forums.electricbikereview.com/threads/clean-custom-conversions.58798/
Definitely mid drive over hub for me.
Only one build, a 750w BBS02B which was very reliable.
If I had to do it today, I'd probably be looking closely at the newer motors @PedalUma is pedaling 🙃
Torque sensor is definitely a more natural feel.
Yeah, the BBS02B seems to have earned a pretty solid reputation for reliability. I can see why torque sensing would be hard to give up once you get used to the more natural feel.
That makes a lot more sense with the numbers — especially backing it down to 18A rather than just running everything at the maximum.
I also like the idea of having the temperature protection set conservatively. I’ll have a read through the build thread and your write-up. It’s always more useful seeing how a setup actually behaves in the real world than just looking at the rated wattage on paper.
Thanks for sharing those.
I'll review my original analysis 11 years ago. I knew I wanted a rear motor because I didn't want the front motor spinning off the bike and me faceplanting, I wanted to pedal, and direct drives have resistance from the magnets when you pedal with the power off. A rear geared motor will coast, so that was the call. An ebay seller was based in Chicago with a warehouse 20 miles away, but I picked a battery seller in China. Selected 36V because it was enough for a 500W motor. Guess I got lucky, Both the motor and battery vendor are still in business, doing quite well. Motor has never had to cpome out of the bike and the battery still works,.
However, after 10 years, I switched to a 48V battery and a different controller.
Last project was the ToSeven DM02 a year ago. I also believe it's a good motor for a light weight bike.
There is a thread on the Great American Wheel Route. She describes her custom bike packing bicycle and what it does for her. In a Substack that is linked in that thread. I set the max power up to 18 amps on a 48V nominal system. With all her off-road bikepacking gear she was able to climb the Rockies. 18x48 = 864 watts. The DM02 controller can take up to 20 amps, but I wanted to play it safe with Summer heat and huge climbs.
That’s a pretty convincing case for keeping things simple. Ten years on the original setup with the motor never needing to come out is hard to argue with.
I also find it interesting that 36V/500W was enough for you for so long, and the move to 48V only came much later rather than being something you felt you needed from the start.
The DM02 seems to be getting quite a few votes here too. Thanks for sharing the history of the build — real long-term experience like that is a lot more useful than just comparing spec sheets.
While I got used to the original 3 speed PAS in my Trek conversion, it was, face it pretty crude, after I started riding torque assist on the TSDZ2, I had a five speed controller with a smoother pedal assist although it's still cadence based. I switched. While the original 36V pack still slides into the same cradle and works, I started using a 48V version. Now here is the silly part. I had to reduce the power on the new controller by 30% so I could maintain the same speed in assist level 1. That allowed me to ride in pace with my wife at 12 mph.
Hi! Recently I bought my first conversion kit, and as it's my first, the minimalism is very important for me, that fact that is easy to install and with good customer support in case you need to solve some doubts. I appreciate the fact that it is lightweight, becuase where I live sometimes i need to lift the bike, and in general i like the feeling of lightness. Considering you are looking for something easy and reliable, i think a hub motor kit can perfectly fit your needs
I agree. For many people a hub-motor kit is quick and easy. I used to be stuck in my ways and opposed. But sometimes a person does not really need a mid-drive and maybe there are budgetary or physical constraints. Budgetary is what it is, physical could be something such as a tandem that has the front rider's chain ring on the left and a left/right chain ring in the rear.
