BE AWARE-IF YOU WANT TO BUY AN AVENTON
GuruUno
BE AWARE-IF YOU WANT TO BUY AN AVENTON Bike
Based on the behavior of the bike and the E34 “Power-on password initialization failure” error, it appears the bike’s ECU/controller initialization or authentication state may have become corrupted. The bike is also unable to properly bind/connect through the Aventon ecosystem, suggesting a possible firmware, controller, or ECU/display/app synchronization failure.
Because modern Aventon e-bikes rely on electronic pairing and startup authentication between the controller, ECU, display, and application ecosystem, a failed firmware event, failed synchronization process, or corrupted controller state can render the bike electronically inoperable during startup initialization.
The fact that Aventon’s proposed remedy is controller replacement further suggests the issue resides within the controller/ECU initialization or authentication system rather than a traditional mechanical issue.
Plain English language:
You are on a ride, you cannot move your bike, you are FUC*ked and can't do a thing.
Just so anyone who may be considering the purchase.....a real world reality
The bike (LEVEL 4 ADV) could be designed to not require communication with “the aventon ecosystem”
Not everything needs to be online / IoT. What happens when Aventon goes out of business and the servers that host the “ecosystem” shutdown?
If I’m understanding the problem correctly, and the current state of “electronic lock” on new Aventon products, this is exactly a reason to boycott the company.
Exactly. Just like VanMoof. IF you are a hacker and know how to hack the firmware, you might revive the bike (like some VanMoof owner have done), but this is the entire point. There should be FULL disclosure PRIOR to making a purchasing decision and if you willingly accept the fact that you are locked into an ecosystem, then it's on you. Otherwise, stay away and don't give it any thought.
Because it was not disclosed PRIOR to the purchase that you would have to live in the walled garden of Aventons' rule. A bike is a bike, and a lot of the technology is cool, but when a manufacturer dictates the ability to turn it on, then it's a different story. You either get it or you don't. Does not mean it has to be accepted. Hence, prior disclosure that should have been part of the knowledge base of info that is provided when deciding to choose this bike.
Aventon dictates the capability of moving the bike in a failed handshake with their server in the cloud. No authentication token, no access, locked, inoperable bike. Does the sales literature that they produce inform the customer of these requirements before the sale as well as after or only after a catastrophic event?
it seems like you have problems with most everything you buy ! have you wondered sometimes what the common thing between all these products you try is? o_O
i've had a vanmoof for 6+ years i think, through the bankruptcy and whoever the new owner is and it still works just fine..... internet, no internet, phone, no phone... i've replaced the front wheel/motor, chain and rings with a belt, etc. it's just a bike.
As someone that's been looking at the Level 4 REC as my first e-bike, Aventon's reliability on tech/network connection has me concerned. I appreciate you sharing your experience!
I may have to go forward with Velotric or Euphree based on my research.
A plethora of my comments on Reddit Aventon forum as well as Facebook Aventon forum. My observations, experiences, etc. No need to replicate here.
This sounds dystopian, the worst part is that IoT is advancing too much and each day we can see how we get more and more dependent to big tech companies. In some years, the real treasure will be analog devices...
Well, there is more to the story.
Screwed again by Aventon​
I have an AVENTON, Level 4 ADV, which I purchased earlier in the spring (April 2026) and I had difficulties with where the ECU died and I had to lose the use of the bike for close to a month while the manufacturer went through their process of validating the error messages and supplying a replacement ECU to the local bike shop.
The bike became inoperable with an E34 “Power-on password initialization failure” error during normal ownership and charging use.
Documented here:
I contacted Aventon technical support multiple times to resolve this matter. During those interactions, I experienced repeated delays and incomplete handling of the support process, including requests for information that had already been provided and no timely confirmation of replacement processing.
So early in June I had a repaired bike.
Recently, on September 12, 2026, I was riding the bike and I had 20 errors and it died on me. 1,655 miles
See the story at: These were the errors:
  • E30 (Controller Communication Error): The display unit and the motor controller have lost signal connection.
  • E33 (ECU Communication Error): The central Aventon Control Unit (ACU/ECU) cannot communicate across the internal system bus.
  • E34 (Power-On Initialization / Password Failure): The startup security and system initialization check failed during power-on, often caused by the ACU timing out while waiting for a response from the controller.
  • E41 (Mid-Drive / Controller Fault): The main drive controller has flagged a system fault or failed to send operational status.
  • W107 (Part Change Warning): The ACU has detected a component mismatch or a sudden drop in communication with a peripheral module, interpreting it as an unrecognized system modification.
I dropped off the bike to a local Aventon dealer to diagnose/repair.
After a period of time, Aventon offered a “bike swap” to replace the defective bike.
I’m still waiting.
They tell me there is no available inventory and any dealers who have them in stock would not be willing to offer one for me through them (Aventon), so I have to await the ‘container ship’ (refreshed inventory) which will most likely be arriving (they say) October. 5th to the 15th. I’d then assume customs to has clear the shipment, then UPS or FedEx to has ship the bike(s) from Long Beach, California to NJ, then the bike shop in NJ will have to prepare it for me to pick up. (Assumptions, as I’m not aware of their internal process to expedite this “replacement”)
I’m also told, that when I do get the replacement bike, the remaining warranty of the inital 2 years will be in effect even if the 1 to 3 months the bike was inoperative and in the shop. Meaning, it’s not 2 years, it is 1 year and 9 or 11 months warranty. Bizarre.
Also, I’m told that because I bought the bike through an authorized Aventon dealer, there can be no refund from Aventon, as they say I did not buy the bike from them but through a dealer!!
So, I’m without a bike, getting screwed on the warranty of 2 years if/when I get a replacement bike, no option for a refund, and jerked around.
As a followup to this, Aventon replied to my request ro give me a 2 year warranty on the replacement bike. My only concern is, how many times will this happen, and will Aventon be aroung in 2 years from now.
Now, would YOU want to buy an Aventon e-bike from them or their dealer(s) give the history of this experience?
