What's the name ??
Nvreloader
Western Nevada
Hey Guys and Gals
The better half wants to start riding, she has tried my 2 heavy weight hunting bikes, and does NOT like the weights, and afraid of falling over.
I have seen a bike she might like, but want to do some research on it.
I don't the proper name for it, but it has 2 wheels, and you kind'a lay down/recline on it, and it has the pedals that stick out the front past the front fork/handle bars.
When riding it and you stop, both feet can touch the ground very easily, one on each side of the bike. Would like to have at least 2" wide tires for the soft ground/sand around here, and must have an electric battery and throttle type.
A 3 wheel bike won't work as we don't have smooth clear trails, always brush in the center part, so it has to be inline 2 wheel type of bike.
What are these type of bikes called/Brand name??
Tia,
RFTH
Thanks for the information, still looking....
I just looked up recumbent bikes and they are all 3 wheeled, won't work for around here, needs to 2 wheeled like a standard bike.
Tia
Here is a two wheeler from trek: https://www.bing.com/ck/a?!&&p=e896...JEMjA0RDUzODlBN0RDMzU1NEI2RjQmRk9STT1JUUZSQkE
A R200. Here is video of how to ride one: https://www.bing.com/ck/a?!&&p=c2e8...faXc2elNJRVB6QTJjbGFIcnZYX2tnJkZPUk09VkFNR1pD
Since I ride on streets & roads mostly, I won't ride one. Scares the willies out of me. My brother has one, but he does not ride much. Warning: they have presta tire valves. Both times I have encountered them, they were *****ed up. Mostly 35-45 mm tires, which are not suitable for trails.
RFTH
Tia
There are two wheel recumbents. See Indianajo's links above.
RFTH
Tia
Getting underway on a recumbent seems tricky because I'd have to swing my foot way up before I could pedal. The guy in @indianajo 's clip made it look easy, but it might not look so easy if I tried it!
A recumbent is a bike you really need to test ride. there are a lot of different types. a long wheel base has you sitting upright an its nto too ahrd to start. but you also need to learn not to pull on the handlebars. they need a light touch.but there aren't many shops that carry them. A crank-forward bike is a good compromise. it lets you be upright and your feet on the ground
those this guy is really where it is at.
As others have said, recumbent. There are lots of 2 wheeled options but recumbent manufacturers tend to only make recumbents so you need to look into them specifically.
Cycling forum grandaddy bikeforums.net has a good recumbent subforum: https://www.bikeforums.net/recumbent/
BentRider Online is a good forum specifically for bents: https://www.bentrideronline.com/messageboard/
Lots of variety to geometry when it comes to bents, you want to test ride some different ones. Generally you want to find a shop that caters to bent riders if you can. Here in the DC area we have bikes@vienna and Mount Airy Cycles.
yes we have one in Portland, though now I only think they do trikes. but you could take a all day ride. its crtical
The Fusion ST is like what I do, but it's more radical. Its seat clamp is about 25" behind the BB, while mine is about 15" behind. This is enough that I can tilt the seat so the front is 5" lower than the back, and pressure on the pedals will keep me from sliding forward. Seated for pedaling, I can't reach the ground, but as I stop, I can easily slide forward and down. As I get underway, pressure on the front of the seat keeps me stable, and I can easily slide up to my pedaling position.
I had a Rans Fusion that I used as a road bike. That thing was great but you pulled on the bars instead of standing, that was a learning curve. There is also the good 'ol Townie by Electra. Don't knock one till you try it! They make many versions for different uses. These styles are called semi-bents.
Hey Guys and Gals
The better half wants to start riding, and she is afraid of falling over.
both feet can touch the ground very easily, one on each side of the bike. Would like to have at least 2" wide tires for the soft ground/sand around here, and must have an electric battery and throttle type. A 3 wheel bike will work as we don't have smooth clear trails, always brush in the center part, so it has to be inline 2 wheel type of bike.
Soft ground, bushy trails? Honestly you sound like you're going to be riding over some tricky sort of ground and even a layback style recumbent like the ones mentioned above would probably be a disaster in such an environment. I'd be looking at some fat tire upright bike, you can have the seat as low as she wants it and start off with high pedal assist and the throttle. Her feet can be easily planted this way and as she gains more confidence you have the option to raise the seat height so pedal power can be used a bit more efficiently. Anyway that's the route I'd take. Actually, It's the route I have taken, but when learning to ride motorcycles on gravel roads. I got a gutless little Yamaha XT 250 farm bike that had a very low seat height, it was like sitting on dining room chair. Once I had some confidence I transitioned to a much higher adventure bike.
Hey Guys and Gals
Tia,
I’ll bet @PedalUma could build you one from an analog recumbent if you wanted. IIRC he was working on one recently.
My wife gets crazy workouts if there are rough trails, headwinds or hills. Otherwise it rides nice for local rides. Electra Townie Ed Roth addition.
The one I will start working on Monday or Tuesday has front wheels that are only vertical when going straight. They tilt when turning so it cuts into corners like someone on skis. The steer tubes angle out from vertical and the wheels are tied together with a rod and ball joints. I am placing the battery on the center bar at the back of the folding seat. The heavy gage discharge wire will go down to the seat's fold pivot, then to the back of the frame, in a hole and up the boom to the mid-drive. The wire will have an 'S' in it so the bike can be extended or shortened for different ridders. The wheel magnet will be on the rear and will take some modifications and heavier gauge wires. It is called Gekkoluma.
Oh, edit, the steer bars are vertical. So if I mounted the display there it would be sideways by 90 degrees. I will cut the 'S'-curve out of a dropbar and use an HB accessory extender bracket to make the display horizontal.
