2wheelsgood
- United Kingdom
As the 4.0 and the 5.0 have different forks I wonder if there is a difference in what tire size they can comfortably accommodate?
With or without fenders?On my 4.0, there is a lot of clearance on the front. It's the rear that's narrower.
Without fenders.With or without fenders?
Yeah it's the seat stays are the issue. Was a bit shortsighted of spesh, I haven't checked tyre clearance on the Vado SL2 I assume it's wider?With or without fenders?
Entirely the other way round on the 5.0On my 4.0, there is a lot of clearance on the front. It's the rear that's narrower.
The issue here is the cable port on the frame is too small to fit yet another internally routed cable. If you tried a dropper with the externally routed cable, know that the sophisticated shape of the top tube, the Mastermind (as well as any bags you might want to carry there) would make installing the cable difficult and extremely ugly.Good mechanical dropper for the SL 1 5.0 EQ?
Rode a bike with a dropper for the first time yesterday. Revolutionary!! Only questions now are (a) which one, and (b) any special considerations on the SL 1 5.0 EQ?
Would appreciate any help in finding a middle-tier mechanical solution with decent quality. Sorry if this has been discussed. Forum search turned up nothing useful on this specific topic.
The only mechanical solution that remains is a hand actuated dropper post such as the XLC SP-T09. You would hate it. To drop, you need to slide your hand between your legs and pull a handle.
Thanks! Will work out a plan of attack with my LBS tomorrow with that cable routing issue in mind. One way or another, I'm putting a dropper on this bike.I own it and stopped using it almost immediately due to the lack of practicality.
If I wanted to use a dropper, I would eventually invest in the electronic one. (I need a dropper on steep descends in rough terrain as well as for riding in mud or sand).
You might want to temporarily replace your Redshift with the original seat-post and give it a rideOne way or another, I'm putting a dropper on this bike.
Still on the original seatpost, and the ride with tubeless tires at 40 psi is just fine.You might want to temporarily replace your Redshift with the original seat-post and give it a rideIf you find your ride jarred then buying a dropper would be of a little sense to you
Oh? Then my remark is irrelevantStill on the original seatpost
When you discuss droppers at your LBS look at the depth of the frame seat tube to see how far down the dropper can go, each bike is different. I think you have the mudguard/fender version so at least you don't have rear light cables coming up the seat tube/seat post. The calculation you need to work out to find the right size dropper post is how much drop you want, and can your frame accommodate the length of post inside the seat tube. Given the amount of motor cables already internally, external cable or wireless sounds the best bet. I would say look at eBay or other second hand droppers, except as it's mostly used by MTBers, I found used ones show great wear and tear, they do tend to get abused. I had an under seat paddle one on another bike for simplicity and cost and it was OK. But I wasn't using it like a full sus mountain biker racing downhill where I needed to drop and raise it frequently, On my rides I had the luxury off stopping to lower it, only to use for big descents and after a while found I could often just flick the paddle while still riding to drop it. To get it back to the tall position I did need to stop, partly the sluggish mechanism. But the paddle felt familiar to me I guess because I spent years in the 80s and 90s tearing over mountains on many rigid MTBs all with quick release seat posts, where without getting off the bike I got into the habit of flicking open the little leaver and using my weight to slam down the saddle. Often with a devil of a job to prise it up again, bottom of the descent!Still on the original seatpost, and the ride with tubeless tires at 40 psi is just fine.
As I said in the OP, this is all about more stable bike handling in certain frequently encountered situations. And I already know from my dropper test that a dropper will make a lot of sense for me in those cases.
The only question here is how to make it happen — hopefully without spending $800.
Many thanks! Exactly my use case.If you want to use it for traffic, for stopping at red lights for instance, the paddle is not suitable, it will get boring pretty quickly. I'm seeing more and more bikes sold with droppers for this very use, not just mtbs.
Droppers also need maintenance, and add weight.
So?An FS e-MTB is not a Vado SL, JeremyJust saying.
Some use oil, which need to be changed. I'm not sure about your Fox Transfer.Good points. How do you know when your dropper needs (a) more air, and (b) a full maintenance?
The Fox Transfer claims to be fully user-serviceable without special tools. I'll need a shock pump to keep the pressure topped up.Some use oil, which need to be changed. I'm not sure about your Fox Transfer.
