Turbo Vado 2 4.0 or 5.0 or 6.0?
A short progress report:
Here's how often a record occurred for a particular cadence. 0-10 have been deleted. (O was far and away the most prevalent cadence - coasting)
In my ride analysis I'm going to use data for cadences 50 to 90. Eliminating the tails will make the slope and P saturation levels more clearly visible in the plots of actual Pm mechanical vs Pr.
Here's how I got the function relating efficiency to cadence
Note the table,
cadence and mech watts are read off the Spec chart.
Electrical watts are the trend line of Pm max values from my data several posts above. Pmax = -0.62 * cadence + 439.
Actual efficiency is (mech watts/elec watts).
The blue line with data points is actual efficiency.
The red curve is a polynomial trend line. You can see from the difference column that it fits quite well.
In my ride data analysis I will use the f(x) shown on the chart to convert motor electrical power to motor mechanical power.
Does this seem right so far?
cool
my guess is, however, that the system is not 84% efficient at 100rpm. more likely it’s just not outputting quite the full 315/320 watts of mechanical power when the electrical draw is only 377w. i think specialized would be crowing about it a lot more if so :)
it’s very interesting that you’re able to get 420 watts of electrical draw out of the motor at 30rpm. i see you’ve got about 25 samples
there. have you tried to sustain 30rpm in a steady state with enough force to keep the power that high? of course the motor isn’t designed to work like this but i’m surprised how inefficient it is. what i would have expected based on the peak power curve from specialized is that at lower speeds you also don’t have as much power draw.
Note the table,
Strong work! If you want something reverse-engineered, best get an engineer to do it.
The above plots for the SL 1.1 (not 1.2) motor is from an official Spec document, but I no longer remember where I found it.
My only concern is the substantial difference in efficiency curve shapes. Yours for the SL 1.2 motor has a good bit more curvature. Could well be the right answer for that newer motor.
cool
I haven't tried that experiment but your statement is correct - It isn't designed to work at that low rpm that means it's less efficient at that low rpm.
It makes sense, The controller applies voltage against the resistance of the windings but the rotating winding themselves generate a current in the opposite direction (back EMF). The faster the motor turns the more back EMF and so the lower net current. Most motor labels show an LRA spec, locked rotor amperage (0 rpm) which is the most current the motor can draw. So the lower the rpm the more current. Running a motor under load at too slow an rpm creates a lot of heat because of the higher current flow (little back EMF)
The current flow (amps * volts = power, volts are a constant 48ish at max "throttle") creates torque and power is torque x rpm. You can see the Spec torque chart fall off a lot as the rpm goes up. It's 50 Nm at 30-40 rpm but drops to 30 Nm at 100 rpm. As the rpm goes up the current, hence torque, drop (back EMF) but since power = torque * rpm the increasing rpm has a stronger influence than the decreasing torque until at higher speeds the back EMF effect overcomes the increasing rpm effect and the power starts to fall off.
Sorry this is so wordy. I'm not an EE but have done a lot of tinkering with electric drive systems for boats and kind of understand this stuff but can't express it elegantly.
You can see the spec chart has a good bit more curvature. I did my best to match the spec chart in my spreadsheet to figure out an efficiency vs cadence function to use to adjust all my Pm electrical to Pm mechanical..
the older specialized chart does confirm very high efficiency at high rpm. it also suggests that the efficiency should be higher at lower rpm, but maybe the new motor sacrificed that a bit, or maybe a longer steady state test would show lower electrical draw?
A hobby once forced me into a fairly deep dive into brushed permanent magnet motors. Our ebikes use brushless permanent magnet motors, but these 2 variants still have a lot in common.
I think you did a great job on a topic that turns out to be a lot more complicated than it looks.
going back to the data, if you consider support factor as the inverse - rider power / motor power, it's actually linear. a very simple first degree equation can go from ease and rider power to motor power - motorPower = (riderPower/(-0.0814*ease)+2.11)
Below is a blue plot of Pm ramp slope S = Pms / Prs based Spec's Prs data for M = 100. The green plot (see below) makes the blue one hard to see.
Symbols
E and M = assist settings E/M
Prs = saturation rider power, here from Spec data
Pms = saturation mechanical motor power
Px = 300W = Pms at M = 100 and 80 rpm.
Approximating S(E)
Also plotted are 3 different ways to approximate the empirical blue plot for calculation purposes. Showed the exponential (red) and quartic (yellow) models previously. What's new here is your hyperbolic model (green). Calling it that cuz the reciprocal of a linear function is a hyperbola.
As you showed, the hyperbolic fit is excellent. And here we see that it's far better than the other two. To improve the fit at higher E values, I added a fudge term H to your formula like so:
S(E) = 1 / (-0.0184 E + 2.111 + H)
Your linear regression gave H = 0, but I plotted H = 0.012.
Before putting the hyperbolic model to work, we'll have to see if the revised field data from @mcdenny supports my hope that the M = 100 ramp slopes also apply to every other M. The Spec data supports this hope, but the original field data stands against it.
Again, well done on finding the hyperbolic formula.
Could you elaborate on that?
The Spec mechanical power vs cadence is significantly curved. If you accept that the electrical power input is constant across the same cadence range then the efficiency curve is going to have the same shape.
PS, I’m taking my bike in to get the new 2” more rise handle bar this afternoon and afterward I’ll try a very low cadence ride at 100/100 to get verification of the electrical power draw at these low cadences. I may have a problem generating the necessary Pr to get Pm electric max at low cadence. We will see.
yeah, that's going to take seriously GRINDING up a hill at 100/100 in a very low gear. be careful, that's the kind of riding that causes people to hurt themselves or have a body <-> pavement interaction.
Not at all, just ride the brakes.
New info regarding efficiency. Thanks @mschwett for suggesting getting a lot more low cadence 100/100 data. Big surprise to me anyway, at 100/100 and Pr above 85 watts the controller does NOT just dump in full voltage regardless of cadence. Just as with Pr vs Pm, there is a linear ramp up to a max then a flat line at higher X values.
Behold
Because the electrical input power is reduced at cadences < 55 my formula for converting Pm electrical to Pm mechanical is wrong. One step back is all though.
The transition point appears to be 55 rpm. The efficiency plot presented above will be revised to have higher efficiencies for cadences < 55. It will be less curvy and more like the one Jeremy posted for the 1.1 motor.
Well it took awhile but here's my final answer from a couple of weeks of recording test rides, downloading .fit files, massaging the raw data and charting Pr vs Pm in many tune settings.
Spoiler: the data doesn't remotely agree with our assumptions based on the Spec tune tables.
I'll post the individual plots with actual points and best fit lines below but here's the summary table:
Again, the .fit files show a snapshot taken once each second and include cadence, Pr, Pm electrical, ease and power tune settings. I eliminated each record where cadence was <50. All the Pm data has been adjusted with the efficiency curve above to be Pm mechanical. For each ease/power tune I took the average Pm for a given Pr. The chart above shows how many records each tune setting had.
One clear take-away: The spec table says 0/100 requires Pr of 670 watts to get max Pm. My data shows Pm is always zero at 0/100. No amount of Pr would get any Pm.
Another: the maximum "boost" is 400% in 100/100 up the max motor output.
This chart shows the differences between 40/40, 40/100, 100/40 and 100/100
My data does show that every tune setting with the same power number gives the same Pm max. Just what we thought. The power setting is not the percent of full power however. The ease setting does not refer to a specific slope (boost). Note the red 40/100 (0.54 slope) and blue 40/40 (1.12 slope) curves.
I'd love to know what you all think. Please try to shoot holes in this. I freely admit these finding seem pretty counter-intuitive.
Here's the detail charts.
Several thoughts:
1. Many thanks for all this excellent work!
2. Will have to mull over these latest findings.
3. There seem to be hidden dependencies at work here. Wondering about a dependence on cadence beyond that through efficiency.
pretty interesting. basically what we see is that the support factor at xx/100 is significantly higher than what specialized claims it is. your observed values on the right, spec data from the reference paper on the left.
that said ... inferring a few more data points than you studied (20, 40, 70, 100) the shape of the curve is actually not that different.
