From Class 2 to Class 1. How "hard" is it to switch?
Bosch motors do have a small amount of delay. Otherwise a bike would jump into traffic while waiting at an intersection with a minor bump of the pedals.
I finally set the time stamp on my camera. It is easier than programing a bike.
It is unnoticeable. Some mid-drive motors also allow setting the Zero Cadence. Fancy this scenario:
You are stuck on a big rock on your E-MTB. Your skill allows restarting climbing the rock, you only need the motor power. With Zero Cadence, the motor will deliver the full power as you set your foot on the pedal and push it hard. Giant/Yamaha have that as the default. You can set it for Specialized E-MTBs. I'm sure Bosch CX Gen 5 can do it as well.
It is unnoticeable.
I'll add this: my wife recently began riding a bike with a Bosch Performance Line CX and a few times now the bike has lurched away from her while she's just about to come to a stop at a traffic light, usually while on a gentle decline but also at least once on a flat street, probably while she's repositioning the pedals.
She never had this on her previous bike with a Shimano E7000 motor.
I'm chalking it up to operator error, or more accurately, habit retraining. Both of my boys and I also ride this bike and we haven't experienced it. So my wife is definitely is doing something different (not necessarily wrong) that must be unlearned.
I'll say the delay/slack is noticably less in my gen4 PL Speed than on the gen2. You can trigger assist while stopped at a red light with pressure on the pedal, especially if you pedaled right up to a sudden stop without coasting. Not really an issue as the only time I would not have at least 1 hand on a brake at a red light is if I'm leaning over tying my shoe in which case both feet are on the ground.
In terms of sudden assist just before stopping, I guess it's more likely to trigger if I haven't down shifted enough and then try to make a last second gear change. Muscle memory is pretty well set at this point to downshift while pedaling without enough pressure to trigger assist as I effectively coast to a stop.
I doubt if that will continue to be a problem for your wife once her muscle memory recalibrates for the new bike.
There are two kinds of 'lag' and 'over-run'. The first is time. It is set in 100 millisecond increments. Visual perception takes 100 milliseconds. You want a little lag such as 500-700 milliseconds so the bike is not too jumpy. The same goes for over run. You do not want it so that if you have a minor adjustment in pedal pressure it abruptly shuts down. The next is set by degrees of rotation, so if the pedal is bumped a little it does not go flying, but is still highly responsive. There is another variable and that is cadence. To be smooth the power delivery curve should ramp up with cadence, maybe peaking at 110. Ideally it will be highly responsive without being lurchy. Then there is the torque sensor sensitivity. As @BlackHand mentioned, you want it to be sensitive, but not jump around if you are not pedaling perfectly smoothly, and you should be able to downshift while coming to a stop. It is set in milliamps.
So I've been riding a Class 2 (i.e w/throttle) for 4+ years, and I'm eyeing a much higher rig (i.e Moustache J-All, or Riese & Muller Homage 5), both Class 1 (i.e no throttle). I do love a throttle when I, or my knees, are tired. I can just stop pedaling for a while and still move. I could not do that with a Class 1 as you always have to pedal to move.
So, if you have switched from 2 to 1, how hard was it to adjust?
Cheers!
Just start off heading towards Pakenham, when you start feeling tired turn around and head back down grade.
This one just came in. It is a Bionx Yuba Mundo that is in perfect condition. The Bionx hub-drive system died and is not supported, making the bike less than useless due to weight and rotational weight. The new owner bought it for $250 on FB Marketplace. This week the old wheel goes and it gets a mid-drive. The mid-drive will be set for maximal smoothness and power, but with a low top speed. It will hall two kids, a tot and a baby. We don't want them to get whiplash.
Can't wait to hear about how all the millisecond adjustments will be made through the display and how it'll be better than any other bike available anywhere.
We'll all take special attention to look for the disappearing wires and magic cable ties as well.
Absolutely nothing to do with the OP... but that's never stopped this useful information from polluting every thread before. 🙃
Hmmm, yeah, very well could be, though this bike has a Nexus 5. Her previous ebike did have a derailleur, but her mountain bike has a Rohloff, her previous pit cruiser / beater bike was a Sram Spectro S7, her city bike has an Alfine, so she's got years and years of experience on gear hubs and being able to shift at a standstill. That's why the both of us are so shocked by this.
So maybe it's not shifting per se, maybe it's that she developed a habit of rotating the crank forward to her preferred starting position rather than backward? I dunno, we're troubleshooting and it doesn't happen all the time, but when it happens the intensity is actually surprisingly violent and she's come off of the bike once!
I find myself pedaling backwards a lot like when setting up for a sharp turn to quickly get the outside foot down. There are places such as when crossing train tracks where you need to quickly go left, right, left to go through the gates. Pedaling backwards does that in one revolution.
Torque sensor bikes kinda work like a Tesla. You push with pedal with pressure to go instead of thumb pressure. On good ones that pressure can be set by the user.
Ohh Yeah !!,..
I gots Two throttles now !!
One for each motor.
I will have the Best E-Bike Ever Available !!!
No Millisecond Delay At All !!
Full Power
TWO Motors
TWO Throttles
TWO Thousand Watts +
Thirty Two legal kph on flat terrain, so I Can't Wait Till the next spring storm bringing 60-70 kph headwinds.
No magic for me, but I did tuck some wires,..
I have nothing to do with that either.
I pollute randomly with stupid pictures to waste your data. 😁
There are several issues with a throttle.
You will get used to not pedalling.
You can catch it while standing stationary and fire off into danger.
It can get jammed on passing foilage and end up with a uncontrolled bike.
There can be strange relationships netween the throttle and the cadece/torque sensor, especially on cheaper bikes.
I have had a throttle stick wide open, and if you dont have cutoff brakes, things can get interesting.
Nosey tyre kickers can push the throttle while its leant against something just to see what it does.
Im sure all of the above are some part of the consultations into the legislation.
I notice the Stark Varg emotorcycle switches itself off if left unmounted for a time to guard against unexpected launches.
Cheers!
Seems to me you answered your own question when saying you use it when your legs or knees get tired. I don't but always use it for a couple of seconds to get underway from a full stop especially if I'm in a higher gear when I make that stop. That alone is enough for me to want to keep the throttle.
I thought the motor was disengaged if you held the brake lever?
@Gionnirocket, With so much hyperbole out there, skepticism is a reasonable check. It is sensible. Okay, let's assume that I do not know what I am talking about and am a boastful fool. That guy with the Mundo cargo bike is picking it up next Saturday. Then within a few days he will write a review on Google Maps for PedalUma eBikes. See what he says about his bike in about two weeks. His name is Patrick.
I'm not sure how that could be possible.
Most hub-motor bikes have brake cutout levers. The levers have an electrical wire that goes to a switch.
