shock absorbing seat posts
I do see some options for a 28.6mm but wonder if a 1/2mm or 1mm to 1.5mm difference is too much to properly fit the bike frame without a shim or sleeve of some sort?
Yeah, you need a shim.
It's worth the five bucks.
I just found this on AliExpress:
C$4.82 | MUQZI 100mm Long Seatpot Shim 22.2 25.4 27.2 31.8 33.9 to 28.6 30 30.4 30.9 31.6 31.8 33.9 34.9 36 Seat Post Tube Adapter
I got one so I could use my seat and NCX seatpost on my new ebike.
I recently replaced my 26" cruiser seat/saddle with something wider with a thicker cushion and recoil springs. I've seen some seat posts that are on some ebikes with some sort of recoil mechanism integrated into the post. Anyone using one of these seat post and do they actually work?
I've got a gell seat cushion on top of a Selle Royal Spring Seat, mounted on an NCX Suspension Seatpot, mounted on a full suspension ebike with downhill forks and 6 inches of travel.
I set my front and rear suspension to Extra smushy.
My ride is so comfy that I have to be careful not to nod off behind the wheel. 😁
Yup. I like the good old days of "mushy" rides. Like when everyone was using a 75 series car or truck tire, like a 205/75/14 or a 235-75-15, so when the roads decayed to "crappy" status you could hit those potholes and bumps and not dislocate a tie rod or ball joint or clamp your butt cheeks. My 1997 Buick has a 60 series which makes the ride worse than my 1991 C1500 with the 75 series tires. Now cars and trucks are using a 45 series tire, or worse, so it's like driving down railroad tracks on our crappy roads. I get used to riding on lower profile tires in the Philippines or terrible roads so when I come home and drive my old truck, I know what I am missing. Waaaaaaaaaaaa! Ha-Ha! I wonder if the fatter tires on bicycles give a nicer ride just like on a car or truck? I am using two ebikes with a 20 x 1.95 and 26 x 1.95 tires. Don't know if I can go much fatter with my wheels?
I am using an Upgraded Saffort Shock absorbing Seat post. So far I really like what it is doing for my ride
Where did you get the gel cushion?
I got the first one on Amazon for ~$20 and the second one on Aliexpress.
The hardest part was finding one that would fit over my large seat.
Both seat covers were really tight to get on my oversized spring seat but they work well and don't slide around.
They have straps that tie around the seatpost and rails to hold the gel seat in place, as well as a pull string to sinch the cover tight around the bottom of the seat and seatpost clamp.
i got a cheap suspension seat post from the bike shop and it's been wonderful, no complaints at all, i dont remember what i paid but it couldnt have been much at all. it was a little too bouncy when i first got it but got used to it and now i love it. well worth whatever money i spent on it. i will likely get front shocks on my next ebike though but the suspension seat post does the trick for now. that was one unexpected thing about an ebike is you hit the concrete cracks and bumps a little faster and my shoulders/hands took a little more of a beating but i think ive adjusted.
I have a couple Thudbusters that help. They're a little springy, but better than nothing.
I have a PNW Coast on a MTB which is a dropper that also has suspension. It has a little damping, but not as good as fork suspension. Also uses an air spring, so you can fine tune it. It's pretty neato.
My Nevo3 came with a Cane Creak Thudbuster, was OK, but changed to an eeSilk and a bit better, both were Elastomer.
Finally changed to a Kinekt seat post, which is an adjustable spring system and is much more comfortable.
DG…
Not scientifically proven by the way but I had one of those simple pogo style posts on my ebike and the rear tire spokes would break. The post finally broke and I put the fixed post back and now the spokes are fine. Either that or the last place I got the spokes repaired at did a better job than the previous one?
One thing to note about the NCX springs is that I found them to be over rated weight wise. I should have been perfect with the stock medium spring supplied when purchased weighing in @165lbs ...but after switching to the Blue soft spring I found it much better on smaller bumps and without ever bottoming out.
ymmv
Another thing to note about the NCX Suspension Seatpost is that there are two sizes of spring diameter.
The SP25 with a larger post diameter has a wider spring, and a replacement spring may use the smaller diameter original spring with a larger diameter black sleeve around the spring.
The sleeve keeps the spring in alignment, and provided the damping by adding stiction to the movement to prevent a pogo-stick bouncing movement.
So a SP12 spring will be sloppy in a SP25 post unless it has the proper sleeve on it, but a SP25 spring won't fit into a SP12 post.
(IIRC, you can buy a sleeve to add to a SP12 spring to convert it into a SP25 spring?)
Buy quality forks, cheap versions are just heavy and prone to severe stiction.
I added Suntour downhill air forks with 160mm of travel and I've got a Rock Shox rear air suspension.
An NCX Suspension Seatpost with a spring seat, and a gell seat cover.
Not sure why you did not just mount a recliner on your bike, it saves some time.
Yeah, I'm working on that.
I just bought a seat with a backrest.
I want lower back support.
I want a 🍌 seat like the Cool 😎 bike I had when I was 12 years old,..
Mine was a gold/beige color.
I love my EeSilk Carbon. I don't want any bounce when pedaling, or compression when I hit the gas.
I added a suspension seatpost to my commuter last year and honestly, it made a bigger difference than the oversized saddle I bought before it.
My daily ride is about 12 miles each way, mostly cracked city streets, rough bike lanes, and those annoying curb transitions that hit harder than they look. Before the suspension post, every pothole felt like it went straight into my lower back. I’d get home feeling way more beat up than I should after a relatively easy ride.
The first ride with the suspension post felt strange for maybe 10 minutes because the bike suddenly stopped “kicking back” over bumps. After a week, I barely noticed the movement anymore — I just noticed I wasn’t standing up to absorb impacts all the time.
It’s not the same as full rear suspension, but for cruising, commuting, or riding older pavement, I think they absolutely work. Especially on rigid bikes or cruisers with an upright position where you stay seated most of the ride.
One thing I didn’t expect: smoother rides also made me more relaxed in traffic at night because I wasn’t constantly bracing for road imperfections. I ride with a SEEMEE400 on the back of my cruiser, and having a stable rear end over rough roads actually makes the light easier for drivers to track too, especially on dark streets with uneven pavement.
Just don’t expect a miracle cure. Tire pressure and tire width still matter a lot. But for comfort? Yeah, I’d install one again without hesitation.
