Best mid drive motor under 500 Dollars?
Bob.A
A bit of background. I've installed 4 motors over the last few years on mostly recumbent bikes.
First was a TSDZ2b on a Greenspeed trike. No OSF, vldc5 display, no throttle. Ran great for a couple of years but then something in the motor went and it developed a vibration under heavy load. I tried the extra bearings trick and that didn't do anything. So far I am continuing to use it since it still mostly works.
Second was a BBS02 I got used with a battery on some old guys project bike. I trashed the bike (thrift store) and put it on a Rans recumbent. It has worked great for a couple of years. I tuned it down so that I rarely go above level 2 and I still get to feel like I am doing a good amount of work. I use the throttle so I dont have to Fred Flinstone it to get it moving.
Third was a TSDZ8 on another recumbent, this time a delta trike. Motor is probably a year old and has the oem programming with the fairly weak pas levels on 1 and 2. I did have to buy another spyder from bikestuff.eu so I could fit a large chainring up front and that cost me 70. Last I checked, to get a cable to program it, would cost another 70 or so and then I'm not sure what the state of the OSF software is these days. It works well enough and if I need more umph, I just hit the throttle a bit.
Last was a T0seven dmo2. That went on a bike for my wife, a Townie. It seems to work fine, not super fast but gets that bike, a Townie up to about 15. Its a fairly locked down controller too, not too many things I can change. I'm not seeing any available, at least on Amazon where I prefer to shop.
Out of all of em, the Bafang seems the most bulletproof. Parts are cheap so if I want to change the chainring, its easy enough. Looking online at Varstrom it seems like they have moved off the UART based controller on to canbus. I have an idea of what it is but no clue as to how reliable it is or if it changes the ability to customize the settings on the motor, which was a big plus in my book.
So I'm looking for any recommendations or thoughts on what might be available. Leaning toward another bafang, probably 750w/48v to take advantage of the batteries I already have. The new bike is a Sun EZ-Rider with the aluminum frame and dual 20" wheels. Not looking for a hub motor and since this will be the 5th conversion in my little fleet, I do want to keep an eye on the cost.
I own four mid drive installs. BBS02B, two TSDZ2, and a DM02. BBS02B is the winner for power and reliability, but I had a setup problem with a 2023 model I did for a friend. Had to use a program cable to set it up like mine. The problem was the factory set speed limits for each assist level, requiring me to change levels as I pedalled. I typically stay under 16 mph, but I still wanted the bike to be unrestricted.
The factory TSDZ2B was just weak. I didn't feel much assist out of it until level 4. My little 250W hub motors felt snappier. Hated it til I loaded OSF firmware and tuned the power so I had the same easy pedalling I was used to on my other bikes. Bought a second TSDZB for my wife, but she hates torque assist and any hard pedalling, Turnes out the OSF cadence mode works perect for her, She says it's effortless. The TSDZ2 bikes are our daily riders now. Occasionally, I pull out the older ones and we ride them to keep them rustfree.
The DM02 was a motor I wanted to try. I did the conversion a few months ago, I prefer the DM02 over the other three for its good pedal response and ability to dig up power with harder pedalling. I think it digs harder than the TSDZ2 too. I like that I can switch between 36V and 48V packs, and the controller automatically increases the current to maintain the same watts. I'm not sure my wife would like it though,
Thanks for the reply. Thats the type I feedback I was hoping for. I like the DM02 as well. I'm just not seeing too many on the market at the moment though. It seems like they locked it down to keep people from modding it and then trying to return it if they somehow bricked it. On this bike I'm not looking to make it a rocket ship, its only got 20 inch wheels so it will only go so fast. Do you know if there are larger chainrings that will fit on it?
I put one on a Townie for my wife. She had a Lectric 2.0 that I hated having to deal with, esp trying to load it in a rack, it was so heavy it took two of us to do it.
@PedalUma has figured out how to program them and supposedly it's not that hard and somewhat manufacture supported.
Every aspect of the DM02 is programable through the display. There are like 150 programable settings and 15 power levels. A couple of weeks ago I programed a four kid hauler cargo trike with 1200 watts max on Sport, level 5. I lowered top speed to 15 mph and lowered the temp sensor cut out. If anyone wants one I can send it.
Here is a 2007 Specialized Crossroads commuter, comfort, gravel bike I just made.
My DM02 was purchased a year ago, so it has open settings on the T-24 display. I have read that subsequent firmware updates for both display/motor restrict the power. Most of those updates reported bombed out too, if you read the Toseven WIki.
The only thing I've done is allow 36V operation, and set current limits of 10, 12, and 14A for the three operation modes. They had been all set to 14A before. I also set the throttle for scooter mode, which should be unlocked speed in all assist levels. but it doesn't do much,
These are my wife's fullsize ebikes. I also built her a 20" folder. On left is a 500W rear hubmotor, a nice bike. On right is her TSDZ2 .
She does like the seats pointed toward the sky. I've ridden the hub motor more than her and think the cadence boost is pretty smooth, but she likes the other bike, I wish I could fit a TSDZ2 on it, but I would have to go 24" wheels front/rear and shorten the cranks.
I think I will convert the right hand bike this winter to hydraulic disks front/rear. I am only lacking the rear wheel in my box of parts, One finger braking would be good for the old arthritis in the hands.
We actually looked at one of those and then my wife asked if we could put a motor on it. I looked it over and after a bit said probably not, at least a mid drive. We ended up getting the Townie for 200 and it looked almost new, nubs still on the tires. She liked the way it looked, so that what was important... As it is she has to ride it with the seat all the way down and the only place I could put the battery was on the rear rack and I had to move it out a bit otherwise the seat would hit it.
If you dont mind sharing, where are you sourcing your motors from?
How are you planning to put a rear disc brake caliper on that bike? I have an old 10 speed steel bike frame that I'm thinking of converting to disc brake on the back and might buy one of these to weld on. The other caliper adapters that I've seen look sort of sketchy.
1761760213203.png\
I normally get them four at a time made to my spec from my rep in the factory. They also supply me with service parts for free and like my builds and that I can do all my own programing and do things like solder inside motors. I do things like have a special motor mount system that is more solid and quiet. Just as I finished that Specialized I have four motors arriving in a couple of days. I will sometimes have motors sent to people out of state and walk them through the install process so it is solid and looks clean and is programed for their needs. It is not like buying from a website in China and it would cost you the same. You would have a known real person who speaks English you can call with a question.
Another choice is Golden Motor in Detroit, MI. They are domestic and know their stuff. With them after tax and shipping it would be about $430. If you get your battery from them on the same order then shipping is free. But they are out of stock.
Four batteries just arrived seconds ago with a fifth one arriving in Texas today.
Here is what a DM02 internal controller looks like. It says 12-18 Amps. If you are running 48V x 18A, that is 864W. It is more than 3X more than the guys raving about their Cuck E Cheese corporate off the rack bikes stuck in the eastern EU. The real deal is so much better. It is all end user programmable, @Jeremy McCreary through the user's display. If it is your bike, then you are the boss of it. There are superior options to off-the-rack.
These clamp onto the frame. The axle provides some support. but it's up to the user to make a more permanent install.
What I do is cut a slot so the axle can slide in and out, and tie the blue part to the frame, with tapped holes. It's much like making a torque arm.
If one could weld, it's aluminum.
Un-hijacking the thread...
I took a ride on the little Sun recumbent, I like the ride and the handling on it, quite a difference from the Rans that is about 8' long from wheel to wheel. What is not killer though, is the average speed I did on about an 8 mile loop, around 8 mph. I used mostly the large chainring in front, a 52t and max speed going a bit downhill, I got it to 15. I'm good with up to 15, thats about what the other 20" wheel bikes will get.
So I would need to be able to fit something large like a 52t on a motor. I have that setup on the TSDZ8 on the trike and while the chainring was cheap, the spyder was not. It looks like large chainrings are available for the Bafang, but not sure about the dm02. That will probably be a deciding factor, even though I'm leaning to the dm02. I could also go with a tsdz2b and keep my fingers crossed that I dont have problems with it.
the spyder
The systems mentioned are all 110 BCD on their standard spyders. So you can use a 110 BCD chainring. I like to use longer ring bolts and chainring spacers to bring in the chainline.
Fingers crossed, I went and ordered a Bafang bbs02 can bus motor off aliexpress this morning. I'm a bit nervous since I've never ordered off them before. But it seems to be the same seller as varstrom and supposed to be shipped from the US. After all the discounts price came to 275 with the ekd01 display. It wasnt much more expensive than getting one of the tongshengs either the 2b or 8. I know I could put a larger chainring on the 2b as I did it with the one I already have. I havent seen any other adapters for the 8 other than the one from Poland. Plenty of adapters and rings out for bafangs and the only thing else I'd need to do is find the upgraded programming cable so I can tone the motor down to my liking. With discounts it came to 275. The dm02 would have been the most expensive out of the lot and while I like the torque sensor, I've been more than happy running the bafang on the LWB Rans.
I also ordered parts to mount the battery, a piece of aluminum angle and an adpater for the existing battery. I'll mount it to the bottom tube with some u bolts which will keep it very low and the power run short to the motor.
I got a couple of pieces of UHMW plastic and cut two wedges to correct for the seat angle which seems to be a complaint others have had with this particular frame design. Not sure what they were thinking with that one.
Not sure you can do much if any programming with the CANbus version.
If that is the case then why sell the programming cable? Can you point me to some online info about it? I can canx the order and go with something else but dont want to take too much time. Thanks.
I think that you want the UART version??,..
I just found this on AliExpress:
C$559.99 | BAFANG BBSHD BBS01 BBS02B BBS02 BBS01B Ebike Mid Drive Motor Kit 1000W 750W 500W 350W 250W 48V 36V for Ebike Conversion Kit
Yes the usb cable is for the UART version only.
As far as I know the CANbus can not be end user programmed in the same way.
I believe some are working on, or may have already hacked the firmware... But from what I understand it's not that easy as it's a complete firmware update.
I've been out of the BBS02B game for 2 years now so I'm not following it that close... But I haven't heard of any progress.
Expand on this in your search.
Another one,..
C$666.99 | Bafang Mid Drive Motor UART Protocol BBS02B 48V 750W Ebike Conversion Kit Electric Bicycle BB 68mm 100mm 120mm
Finding the UART version on Aliexpress appears to be difficult.
It's probably best to chat with them to verify that it is UART and not CANbus.
If they don't seem to know what you're talking about, then try another vendor.
