Are these normal phase wire voltages?
Vic Dupont
Europe
Hi there!
As I am trying to troubleshoot a problem on my electric bike, and got stuck, I tried measuring the voltage on the phase wires, to know whether my controller is faulty.
I would like to know whether that looks normal or abnormal to you, since I have no idea what the correct values are, and I don’t know whether my methodology makes sense.
The way I measured is the following.​
In order to have something that might make sense, I disconnected the phase wires from the motor, so that it doesn’t move. I kept the hall sensors and speedometer wires plugged, so that the controller has the information coming from the motor. I disconnected the brake cutoffs and lamp, to avoid them interfering. I also opened the controller, to be able to measure voltage directly on the circuit board, to rule out potential wire issues.
Basically it’s a pretty normal setup, except for the phase wires that are disconnected and the controller that is open.
I turn the pedal when I want to measure, and then I use a basic multimeter to measure voltage on each phase wire’s solder point.
Again, note that the motor doesn’t move. The pedal movement just ensures that the controller gets the signal to kick off the motor.
In order to change the sensors value, I simply turn the back wheel backwards and measure the hall sensors wire solder points to know where it landed.
Let me know if you think this method of measurement is not usable.
If it's of any use, my controller is a Lishui EPAC Drive System, part number LSW06-90B1CF SB.
Here are my results:​
When idle, meaning pedal is not turning:
When turning pedal:
Some things to explain:​
- I made several experiments for each motor position, and noted the result of each measurement, separated by commas. I made sure to turn the wheel, and thus change the motor position, between each experiment.
- when I include an arrow, such as 0->9, it means that for a few seconds it was at 9, and after maybe 4 or 5 seconds it rose to 9
- twice I had results that were the same as when idle, and controller’s light was flashing differently, not regularly. After I turned the wheel it went back to « normal ». That’s what I indicated as « flashing ».
There are a few things I notice:​
1. when idle, meaning the pedal is not turning, the yellow phase wire has 13 V voltage when measured using DC mode on multimeter. I would have expected 0V.
2. my measurements when pedal is turning seem to hint that in a normal setting, each phase wire would be at either 0 or 35V, which is close to the battery’s voltage, and that the wire with the 35V would be a color that is at 3.3V in the hall sensor cables. This is just my guess, tell me if that’s how it’s supposed to be
3. It seems to me that the most abnormal measurements seem to be on the yellow phase wire, when it’s supposed to be at 35V, and is instead at 6 or 8V
But again, I am just guessing, I have no idea what the correct values are.
Do you know whether these values are normal or not?
I previously tested for shorts between the phase wires, ground and battery positive, to detect a blown transistor, but everything seemed normal.
Other measurement : with motor connected
I also tested voltage on phase wires when they are connected to the motor. That way everything is exactly as in real life, except for brake cutoffs and lamp which are disconnected.
I only tested when it's idle, meaning I am not turning the pedal.
Here are the results:
As you can see, there is voltage even though everything's idle.
If my understanding is correct, phase wires are connected through the windings in the motor. Thus I interpret this as controller sending 13V on yellow phase wire, and because others are connected to it through windings in the motor, they are all at 13V.
For those who are interested in the whole history of this bike’s problem, here it is: https://forums.electricbikereview.com/threads/temporary-power-outages-and-motor-noise.57987/
Thanks a lot in advance for the help!
I feel you're wasting your time.
Best way to test a motor is to hook it to a good controller. Conversely, you test a controller by hooking it to a good motor. Here's two schematics for popular controllers that are representative of motor drives. You can examine the mosfet drive circuits,
  • S06S_schematic.pdf
Thanks a lot for the reply, and for these hints!
I agree 100%, I would love to be able to plug a known good controller. The thing is, I don't have any at hand. I could buy one, but apart from the money matter, I feel like it would also be a waste of many resources if my controller is not the problem.
Conversely, I feel like the methodology I came up with, if it turns out to be meaningful, could be very useful to many people who are not bike repair professionals. It would enable anyone with a multimeter to test the behaviour of their controller without having to buy another one, and even without having to wait for it to arrive.
Looking at the numbers I measured, do they seem normal to you?
Among other things, is it normal that the results are different for the three wires? I would have expected things to be symmetric. Is there usually an intentional asymmetry, which could explain that my yellow phase output doesn't look the same as other colors?
Similarly, is it normal that I measure a 13V voltage on the yellow phase even when everything is idle?
Again, thank you very much for the help, I really appreciate it.
It's all digital in the end. The controller only looks to see if the Hall signal is above its digital Vin, probably 2V. However, your Hall outputs, which I didn't look at, should be similar.
As for the 13V, you;re the circuit guy, I gave you two typical drive circuits to get you understanding it, Figure it out.
I saw your other thread. Summers almost gone. Your girl friend didn't have a bike to ride for months, WIth the right gear, someone could have figured out whether motor or controller in an afternoon,
I personally think that the controller is at fault, be it a mechanical hardware/connection issue or a programming software issue
Your motor obviously works.
You got it spun up.
The motor is a much simpler device than all the inputs and software that controls it.
And a dual mode controller can spin up a wheel with no hall sensors at all.
I say Waste some money on a new controller and enjoy the rest of the riding season.
Your girlfriend may thank you for it.
Your test method without load is useless.
Best test of a controller phase outputs is an AC current meter. They have a clamp that goes over the wire under test. I got mine for $29.95 at Sears (deceased). Test while riding the bike (difficult).
New controllers can be had for $30-75, and I have never had one last over 3 years. I've been through 6 controllers and 5 motors since 2017. First 2 batteries I bought were bad, and I proved it buy buying a whole Direct Drive kit ($299) that would not climb hills either. Note 350 w controllers will fault out loaded by a 1000 w motor, and 1000 w controllers will burn up a 350 w motor on about the 5th hill.
Hi guys!
Thanks a lot for the help!
I added another measurement to the first message in this thread. I tested with phase wires connected, and everything idle. I still got 13V. See above.
The goal was to be closer to real life.
With these new pieces of information, can we conclude that controller is faulty?
Yes, I took a deep look at it, it's very useful.
The problem is that I don't know what the CPU is supposed to output, whether it's supposed to be symmetric or not.
As a consequence, even though the MOSFET driver circuits seem symmetric, I don't know what the end result is supposed to be.
Do you know? Are there controllers that send a different pattern on one of the phase wires than on the others?
Similarly, because I don't know what the CPU is supposed to do, I don't know whether it's normal or not that there's voltage on my yellow phase wire even when everything's idle.
Do you know?
I would love to be able to conclude whether my controller is faulty or not, so that I can move forward.
Thanks a lot again for the help!
Thanks a lot for the reply!
I would love to understand, in order to learn and be more able over time.
Could you please explain why you think this test is useless? The measurements I made look like a normal controller behaviour?
Meta message for those who are interested in my motivation and my partner's situation
I'll explain why I made the decision to try and fix the bike myself.
First off, it's not a mountain bike, it's an urban bike. My partner was planning to use it to get around, run errands, go to work, etc. Since it doesn't work for now, she is still using her motorbike. It's not a big deal right now. It's going to be more problematic in winter, because the motorbike tends to not start in the winter, and the motorbike repair shops around us never found the cause, despite us bringing it to them countless numbers of times.
Thus it was not a problem to not ride it during the summer, the deadline is the upcoming winter.
As for the time I took so far, I could not foresee that it would be that much. At first it looked like it could just be loose connections, then another hypothesis, then another one, etc. Each time, I couldn't know whether I was 15 minutes away from the solution or not. As of today, again it may be that I am very close.
In any case, I don't regret the time I spent.
Why? Because I wish to learn.
I have spent a lot of time on this bike, mostly because I didn't know anything about electric bicycles. I have learned a lot now, and I feel like next time there's a problem, it's likely that I'll be able to troubleshoot it very quickly.
The goal is to be able to be as autonomous as possible in the future.
Again, a very big thank you for all your help. You have contributed to making me learn, and hopefully to be a lot closer to the goal of repairing this bike. I really appreciate it.
Hi guys!
I am extremely surprised that no one seems to clearly find my measurements normal or abnormal, that no one seems to find it normal or abnormal that my measurements are asymmetric, or that there is voltage when the bike is idle.
Is this just a misunderstanding somewhere in the discussion, or is it really something you have no idea on?
Thanks again for the help!
Again, thank you very much for the help See more info, I really appreciate it.
Yes i see The controller simply checks whether the Hall signal rises above its digital input threshold—likely around 2V.
