Ebike helmet
Elias
I recently got a class 3 ebike. Should I consider getting a special ebike helmet certified to the NTA-8776 standard? I'm looking at the Smith Dispatch and the Specialized Tactic. I'll mostly be riding around San Francisco and occasionally some fire trails.
or will a regular helmet (like the Giro Register 2 Mips, Giro Source, Smith Engage, or Smith Convoy) be just fine?
No helmet is needed if you don't fall off your bike and land on your head. And never land on your head because even with helmet it can be bad.
If you are really worried about a head fall a full face helmet would be best. The NTA-8776 looks good, but that's for MTB riders. A road bike helmet should be good enough to prevent the worst of traumatic brain injury. MIPS is a definite plus. I should of asked this first, but what kind of riding do you do? It would help if you posted the links for your helmet choices.
If you are really worried about a head fall a full face helmet would be best. The NTA-8776 looks good, but that's for MTB riders. A road bike helmet should be good enough to prevent the worst of traumatic brain energy. MIPS is a definite plus. I should of asked this first, but what kind of riding do you do? It would help if you posted the links for your helmet choices.
Ok updated my post.
Most premium MIPS helmets are NTA-8776, only the manufacturers do not brag about it. Giro, POC, Specialized...
Contrary to what gromike said, NTA-8776 helmets are not for MTB riders but for the riders of S-Pedelec, or U.S. Class 3 e-bikes.
The latest helmet rating.
Smith helmets are even not there.
does that suggest I should stay away from Smith?
I wouldn’t make that leap… Wanna’ bet Smith just didn’t ante up with supplying this lab with helmets to test?
Having said that, if you’re looking at a helmet that is on this list, the data certainly looks valuable for assessing/comparing.
Honest question: Is an ebike-specific helmet really necessary?
Most ebike riders can't pedal much beyond their max assist speeds, and a fit roadie can match those speeds on the flat, though not for long at 28 mph. All parties can in theory exceed 40 mph on descents.
Aren't non-ebike helmets designed with those worst-case scenarios in mind? If so, what about an ebike warrants further special treatment?
Are there really e-bike specific helmets? Doesn't make much senses to me since both bikes under normal conditions go about the same speed. If this is true it sounds like a marketing ploy.
I also did not know there were e-bike specific helmets. The Dispatch(eBike) is 100g/0.22lb heavier than the Engage (MTB), based on the specs. The Engage has 3x the amount of venting, likely commuter oriented helmets are more rugged and cooling is not as critical as a MTB helmet used for multiple hour rides? Dunno? I ride my Creo2 with a Mips Fox Speedframe Pro helmet.
I don't know of any, and never considered it in my last (well-reseached) helmet purchase 8 months ago. Never even came up.
But the OP kinda suggested that ebike-specific helmets exist — maybe even with a formal standard. I'm not researching it, but if there's not really a standard, agree with marketing ploy till proven otherwise.
OP should find the Virginia Tech helmet testing site and use their widely respected results as a shopping guide.
The NTA-8776 certification was developed specifically for ebikes in the Netherlands. Some US helmets have it, such as the Specialized Tactic (which has a high rating from Virginia Tech).
Interesting. Any idea how ebike helmets differ from regular helmets?
