Brake pads don't require extreme precision. You can simply run them through a grinder, it's very doable, I've done it more than once...I can find material down to 1/8" thick, just can't find anything thinner. Need to go a little thinner.
Me too. I've made my own aquarium pump and heat controllers, leak alarms, wet/dry filter and aquarium stand. Here I made my first ebike and then smart charging adapter.I am a committed do it yourselfer. Converted my cargo bike to electric myself. Right now I am trying to bend the back of my 48" mower deck back to not drag the ground, and stay that way. A $550 problem, plus the OEM design was subject to snapping down to drag as sold. Brake pads are a $10 problem. I bought mine on e-bay, since there were 999 models of metallic ones on modernbike.com and universalbikes.com . Organic stops faster, does not require as much force. Metallic is for downhill racing IMHO.
Heat is a thing on brakes they would need braised on. plus the materials would be expanding and contracting in use all of the time. but hey Darwin loves cheapskates.Probably just a two part epoxy would work fine.
Maybe that should be the forum motto.Darwin loves cheapskates
I would just laminate layers of 600 grit sandpaper to the desired thickness.
This way you polish the rotors when you brake.![]()
Hi, Just curious, your motivation for 'rolling your own ' : ) brake pads ?A person can buy material for thicker brake pads, I have yet to see any thin enough for the bike pads. Somebody is making a killing on these things. I am coming up on needing a set. Anybody find any thin enough for our pads?
