brake pad material
Marcela
A person can buy material for thicker brake pads, I have yet to see any thin enough for the bike pads. Somebody is making a killing on these things. I am coming up on needing a set. Anybody find any thin enough for our pads?
I am a committed do it yourselfer. Converted my cargo bike to electric myself. Right now I am trying to bend the back of my 48" mower deck up to not drag the ground, and stay that way. A $550 problem, plus the OEM design was subject to snapping down to drag as sold. Brake pads are a $10 problem. I bought mine on e-bay, since there were 999 models of metallic ones on modernbike.com and universalbikes.com . Organic stops faster, does not require as much force. Metallic is for downhill racing IMHO.
I can find material down to 1/8" thick, just can't find anything thinner. Need to go a little thinner.
Brake pads don't require extreme precision. You can simply run them through a grinder, it's very doable, I've done it more than once...
What do you bind them with, Id feel happier making my own if that sat in a shaped holder so they couldnt suddenly start spinning around with the disc, whack you in the eyes and then youre blind with no brakes.
I am a committed do it yourselfer. Converted my cargo bike to electric myself. Right now I am trying to bend the back of my 48" mower deck back to not drag the ground, and stay that way. A $550 problem, plus the OEM design was subject to snapping down to drag as sold. Brake pads are a $10 problem. I bought mine on e-bay, since there were 999 models of metallic ones on modernbike.com and universalbikes.com . Organic stops faster, does not require as much force. Metallic is for downhill racing IMHO.
Me too. I've made my own aquarium pump and heat controllers, leak alarms, wet/dry filter and aquarium stand. Here I made my first ebike and then smart charging adapter.
But at less than $4 a pair... I think I'll pass on making brake pads
I changed a set on an ebike I really liked( no longer own) those things squealed twice as loud as a wounded rabbit( in retrospect I now know what was wrong) just experiment a little something will work out it doesn't cost that much for brake pads,I kinda liked the "squealy" pads it got the deer out of the way.
Mcmaster carr has a pretty good selection of friction material. Still nothing thin enough, only 1/8” thickness, which may work on some of the bikes, just have to investigate. Something like jb weld and a vise I would think would suffice to hold the material. Probably want an adhesive that wasn’t too aggressive if it touched the disc.
AI sites are full of lots of the answers to the stuff we ask about. What kind of adhesive is used on break pads. Just ask An AI site. Just don't get carried away and get addicted. One question leads to another and pretty soon you are sitting at the computer for a long time asking on question after another.
Hi, Just curious, your motivation for 'rolling your own ' : ) brake pads ?
Thanks,
John
