Help! Bought a used ebike with battery/BMS issues..
WheatyPop
Recently I bought a used Velowave Ranger ebike, and I have spent quite a bit of time fixing it up. I finally had it up and running, but I discovered a pretty severe issue with the battery.
The battery works fine during pedal assist 1 and 2, but if I go any higher, the battery will shut off and not turn back on. Full throttle has the same effect. After I plug the battery into the wall, it will turn on again. This seems to be a problem with a weak or unbalanced battery pack - I just don't know how to fix it.
I'm currently trying a long top-balancing session to balance the cells in the battery. I'm not much of a tech guy so any help or assistance is appreciated. thank you
That happened to me because a bike had sat too many weeks or months. I plugged a watt meter into the wall, a timer into the watt meter, and the charger into the timer. (Watt meters and timers can be under $10 these days.) The watt meter gave me an idea of how much charging was going on at the moment. The timer was to be sure it didn't continue to charge when I was away. I'd charge it in increments of an hour or two. It worked out well.
Just to add to what @spokewrench said, please be careful if you do this to try to revive and balance the cells. Do this in a place that’s away from combustible materials. If a battery has a weak cell, there can be several reasons for that, some of which may not be repairable by recharging.
If a lot of heat is being generated with your charger on you might want to be circumspect. Do you know anything about the history of the bike? Good luck!
@spokewrench My bike has also been sitting for quite a few months, and this could be a similar issue. Do you think you could elaborate on what I need to do and look for when using the watt meter and timer? The battery is sitting at 100% currently also. Thanks for the help
If it's at 100% then it has no problems. How are you determining this?
I would read the voltage at the output terminals to better understand it's condition.
If it does have storage related issues you may be able to coax it back to reasonable health by slow charging. I doubt very much that your BMS has the ability to balance charge.
Also don't leave it at 100% as that is harmful to battery health as well. Store your battery at approximately 50% and charge it to the desired level before riding.
I'd see what the watt meter reads with the timer on but the charger disconnected from the battery, probably under 2.0 watts. With the battery connected, that's what the watt meter should read if the BMS has really switched off; sometimes I've seen a green light on the charger, but the wattage showed that the battery was drawing a little.
Typically, a charger will draw more than 100 watts and taper to almost nothing. In this case, the taper was slow. I believe battery fires usually start during charging, and it takes time for a bad cell to reach a critical temperature. When the taper took too long, I didn't feel any hot spots, but I shut the timer off for two reasons: so I could leave the area without worrying, and to let things cool in case a cell was dangerous.
Then, when the charger would show a green light, I'd shut the timer off and turn it on later to check. The first time I checked, the green light didn't come on and the charger wanted something like 10 watts. I'd charge until the BMS switched off, switch off the timer, and come back later to check. Something that might be called balancing was happening when the charger was off. On each cycle, it asked for less power until it didn't ask for any. It probably would have balanced if I'd simply left the charger on, but I would have been uneasy.
I had no more trouble with that battery.
If it's badly unbalanced, as you probably know, just one cell group may be stuck a little above the 3 Volt minimum, and a heavy load like full throttle causes that group to sag below the minimum and shut the battery off.
Looking at the overall battery voltage probably won't show that unbalance, but it would be good to know what you are getting after the charger turns green, Got a meter and care to say what you measure?
I doubt that many inexpensive batteries put in balance BMS. It might actually be safer to retire the battery if some of the cells are badly unbalanced. That's a sign of deteriorating chemistry when the cells can't hold charge like their neighbors. If balancing forces them above what they can sustain, in a worst case scenario, they might overheat.
Probably most e-bike batteries lack active balancing, but if they didn't have passive balancing, their service life would be short. In passive balancing, each cell is protected by a shunt which at a certain voltage begins bypassing current. That way, if there are 13 cells in series, you can shut off a charged cell while others continue to charge.
The problem is that at the shunt voltage, the charged cell will continue to charge, albeit very slowly. Suppose of 13 cells in series, 12 are slowly overcharging while shunt current charges the undercharged one. If the 12 each reach .01 volt above fully charged and the low cell is still .12 low, the sum of their voltages will indicate that they're all fully charged, and the BMS will shut off charging. That's why some say passive balancing is inaccurate as well as slow.
Even a new battery can arrive unbalanced, due to cells with different self-discharge rates over a period of weeks or months. As of 2020, Radpower's instruction for a new battery was to leave it on the charger 12 hours, take a ride whether 20 miles or around the block, charge it another 12 hours, take it for another ride, and again leave it on the charger 12 hours.
A lead-acid car battery may be fully charged at 12.6 volts but come off the charger at 13 more. With car batteries, that extra voltage is called surface charge. In a car, you can drain the surface charge by running headlights a few seconds or letting the battery sit a few hours. With an e-bike battery, you need to drain off possible "surface charge" in some cells for the BMS to tell if other cells are undercharged. Radpower recommended taking a bike for a ride to drain surface charge, but I just let a battery sit an hour or two.
Can you provide a source for this information as it's contradictory to all I've read. Are you saying this information is provided by Radpower? If so, I'd be very interested in seeing it.
Most low cost batteries lack any balancing ability... But if quality matched cells are used, it's not an issue.
Passive balancing is done with a bleed resister that absorbs the excess energy and prevents full cells from charging further.
And if your new battery arrives unbalanced... It's garbage. A new well matched pack will stay that way until used or abused.
