Gionnirocket
Well-Known Unidentified Member
- USA
- City
- Y. O.
I wouldn't worry about the battery LED syncing with the display.On my most recent DM02 build the battery would show three bars and the display would show half-a-bar. I used this chart to help sync them. Then I had to refine it.
eBike Displays & HMI for Hub and Mid Drive Motors | ToSeven
E-bike displays and HMI units from ToSeven, built to pair with our hub and mid drive motors. Clear real-time readouts for speed, assist level and diagnostics.to7motor.com
Personally.. I would set my desired LV cut off in the controller (39v seems safe enough as that's still a little over 22% on the average 18650 cell) and use that for 0%. Keeping in mind it should be a little higher than the LV cutoff on the battery BMS. Hopefully the BMS isn't set at an overly protective high voltage.
But then Wtf do I know
