stompandgo
- USA
You mean swap the batteries at each end of the Y? I'm not sure what you mean.
I think your bike is pretty awesome. What more modern tech are you referring to? Just curious.Today I added a used Cane Creek Eesilk + seatpost that needs rebuilding, a loaner saddle for testing, swapped the stem for a 3T 130mm -17 degree stem, and removed the dead horn which is being replaced under warranty. I would love a lighter bike with more modern technology, but this beast is so much fun to ride. It absolutely was built to ride fast.
At the shop, we have two licensed computers with the Bosch diagnostics, and I've learned how to use them. My lighting port is already set up for high output, as the bike came with a Supernova M99 Pro Mini headlight (1300lm), Supernova horn, and a Supernova tail/brake light.
When I first returned to cycling 3 years ago after 20+ years away, my minimum balancing speed on the bike was 6+ mph. Now it's comfortable down to ~3.5 mph.Thanks, and it's stable at any speed over walking speed. Below that, I'm a hazard.
