So cylinder had gone in the rear brake lever. Not worth fixng as the labour cost could approach replacement cost. Pads were low as well. The staff in the new bike shop were super enthusiastic and gave it a pretty full inspection on the spot. Chain needs replacing and as it is due a service I got it booked in.
The guys also suggested the exact same rotor upgrade as Stefan mentioned a page or two ago. When I mentioned I was never impressed with the brake lever action on the Tektros they directed me to a Cube which had Shimano BL-M8100 XT fitted and after a little go on them I was convinced to go with those with M8110-XT 2 pot callipers and the cool looking Ice rotors.
Truth is, I think I am much harder on my brakes than I probably realised as I often use the bike for speed workouts which often calls for full on brake workouts as well.
A bucket of bolts no more!
Recently reported a horrid clatter coming from my SL. Thought for sure it was from the motor, but no — it was a dry freehub!
My mechanic cleaned and lubed it up, and now the noise is gone without a trace. Guessing an assembly error that took 2100 mi to show up. Fortunately, no damage done.
The lesson: It can be really hard to tell where bad noises that only occur while riding are actually coming from. These are noises that for one reason or another cannot be reproduced on a work stand. In this case, the threshold pedal force was just too high.
I'm a mechanically minded guy and a careful observer by training. I worked hard to pinpoint the source of this noise.
Paid very close attention to what the rhythm did and didn't sync with. Rode 2-3 miles of neighborhood laps trying (a) to triangulate it from the saddle, and (b) to see what triggered it, what made it better or worse, and what made it go away. Sounded like it was coming from the motor area every time. Besides, what else could make such a sound?
And after all that, I still got it dead wrong! Had a similar experience when my hub-drive's bottom bracket bearings wore out.
It's good to hear all ended well. Nobody would throw stones at the Deore XT class brakes, and the Ice Tech rotors certainly look beautifully! A nice upgrade indeed. I assume it was expensive, including labour?
True. I recently described an unpleasant squeaking noise that I thought was coming from the front of my Vado SL. In fact, it was caused by dry suspension seat-post internals! (Sometimes, bad noise can be caused by something banal). Good Jeremy the noise cause was identified and fixed!
It was when I was a freshman on my Giant Trance E+. Once, I was on a forest ride and emerged onto a sand road at the woods edge. I was just thinking 'e-bike motors do certainly break; I wonder when it happens to mine?' when I heard a terrible noise, for sure from the bottom bracket area. Oh no!
It was a dirt motorbike roaring behind the trees :D
Or,
when you are sure the replacement of your M5100 derailleur pulleys after 15 months and 4,400 km post the new drivetrain installation is necessary. You have bought a new pulley set and diligently work on the replacement. Meanwhile, small parts constantly fall onto the floor, so you have to search them using a torch/flashlight. Eventually, you discover the old pulleys are not worn at all, so you only clean them, and your hands become black :D
It certainly wasn't cheap! along with the full service, labour, new chain, full brake set etc it came to nearly 500 british pounds.
Quick turnaround, they phoned this morning to say all parts are in and I could get it done by the end of the day - I was down there in 20mins. More money than I expected (isn't it always these days?) but I am quite impressed by the result, my index fingers naturally curl around the levers now and a gentle squeeze offers great control of stopping the bike. I am sure they will get better as well when they are bedded in.
It also seems the guy who fitted my AXS upgrade last year did not really know what he was doing and the gear changes now are much smoother and more positive.
Annoyingly the saddle height and angle had been adjusted. it took me ages to get that just right for me so I will have to go through that process again but I guess on a full service they have to check it.
Glad you have your bike back! Losing a hard-fought seat adjustment is a terrible thing.
But what can you do? It's a violation of the Law of Conservation of Aggravation for everything to go right. And you don't get to pick what goes wrong.
The single brake assembly is at least 100 quids (or more). The Ice Tech rotors are not cheap either! I think the shop has charged a lot for labour, as they had to route new hydraulic lines inside the frame, and that's a lot of work. Well, the brakes you ordered are high end, and I am not surprised you can brake easily with one finger :) Only exercise care and never pull the levers too strongly! (Sure the brake pads require bedding in).
Brilliant! This is what you paid for! My experience with the AXS is you even do not know when the shift has occurred, such good the drivetrain is!
I put notes (at least mental) for that. I measure the distance between the centre of the motor spindle to the top edge of the saddle along the seat post (70 cm), the distance between the tip of the saddle nose to the steering tube centre (44 cm), and I always set the saddle angle at 0 deg using the Bubble Level app in my smartphone.
FYI.. Chatted with Specialized support, because I was annoyed that I still can't see firmware status or possible updates via the specialized app. They said it was coming in the new version of the app sometime soon (last year). Same story last week. They are working on it. argh..ah well..
Thirty miles with lots of steep hills and speedy rollers to stress the drivetrain, and still no trace of the god-awful clatter that took the SL to the shop.
Still can't believe that sound wasn't coming from the motor, but the proof's in the pudding. If I ever again dare to tell a mechanic where I think a bike sound's coming from, it'll be with a big side of humble pie.
Jeremy, there is a well known secret of DT Swiss: the brand packs new freehub bodies with grease to the top. Once installed, a rear hub such as the famous 350 is completely silent during coasting. Until the grease wears :)
Very interesting. My DT Swiss rear hub was quite loud from day one. Wife even commented on it on a recent ride. I'll check the coasting sound now that it's been lubed and report back.
A few days ago, I did my longest ride ever on my Vado SL at over 40 miles.
This was almost all offroad on crushed limestone and dirt. We have some great, well-maintained trails here that stretch for hundreds of miles and there was a particular route I've always wanted to try. I finally built up the necessary leg endurance and courage to give it a go.
This path gets pretty far into the wilderness, so I was concerned about having a breakdown, but the bike hasn't left me stranded yet, so I figured I'd go for it.
I started with a full charge on the main battery and a fully charged range extender (and a freshly cleaned / waxed chain). I set the range extender to discharge first and then switched to the main battery. The bike had PLENTY of charge to do this ride and I ended up with 55% charge remaining in the main battery.
By the time I got home, the bike was covered in trail dust and needed a serious wipe-down.
Overall, it was a great ride and I think I'm going to push it a little further next time. My goal is to follow this series of trails to the very end near my state's border. It will probably be about 60 miles.
Riding these offroad trails is much more challenging than riding on paved trails or the street. Some parts are very technical, with a lot of hills, twists, turns and wildlife. You've really got to be on your toes since it requires focus and can be mentally challenging as well as physical.
Pic of bike at a rest point near the 20 mile mark. You can see the dust build up already.
Zipping through the woods, maintaining a good clip while trying not to wrap myself around a tree.
Always be careful and courteous when passing horses:
Open field:
Trail narrows here. Lot's of twists and turns. Gotta be careful.
Ride summary data:
Is your Vado SL a Mastermind one? If yes, start at 50% MicroTune assistance. Have the Range and Range Trend displayed on the Mastermind screen. The Range Trend will be positive with a tailwind or downhill. In case you encounter headwind or a climb, the Range Trend will become negative. Also pay attention to the Range data. You can go with the Microtune assistance up or down as needed.
In case you have passed the ride midpoint and the total battery charge (Main + RE) is 83% then you are good to go unless you expect more difficult climbs or headwind (watch the Range figure closely). In the latter case, you must reduce the Microtune Assistance to get at least neutral Range Trend.
