Bosch Nyon Retrofit
2KTucson
Installed the Nyon controller on my Synapse NEO 2020 and it is fantastic. Maps load effortlessly, easy sync with the Cannondale app, and uses very little power. Slick!
Has Bosch said how long they will support it? I could replace my Kiox with it and no longer need the Garmin.
I know they stopped supporting the Kiox. I usually use the nyon for navigation if I need it but you need to make sure you setup the route before hand. but I don't do that much navigation so not sure how robust it is in hard use.
I got my Garmin before Nyons were available, so I use both, mostly for radar temp evaluation, slope, and such. I also used it to recorded to strrava till bosch made that work well.
