I think he should send the battery to you so you can save it.Lucky you are here to save us
you are most welcome grasshopper!Lucky you are here to save us
I'm sorry grasshopper, no one claimed you don't have knowledge, we do know the battery and maker. Enough to know it's best to call it a good run, which you also eventually suggested. Don't be butt hurt. Unlike endless_sphere, this forum tends to be beginners and don't have the tools or knowledge mess with battery repair.Weird the person claiming I don't have knowledge thinks 48v/13s packs stop charging at 45 volt because it's made in China.
If I quit every time you gave me 5hit! Now I need to Brazilian Wax these chains for a cargo bike to get that smooth fresh feeling.Hey... That worked out better than expected![]()
Tom,No not worth the risk for anyone new to battery repair and I'd say you got your monies worth. It's probably a Unit Pack Power battery. A bottom of the line build. Anyone suggesting balancing without demonstrating their skill set should not be trusted given the risks.
that's not always the case. It's a pack with lower quality generic Chinese cells from a company known for failures. Someone published data and warnings about that pack.
AI Overview
Learn more
The Consumer Product Safety Commission (CPSC) has issued a warning and recall for Unit Pack Power (UPP) e-bike batteries due to fire and burn hazards. These batteries, often sold as "U004 BATTERY" or "UPPBATTERY" and rebranded as "Unit Pack Power" or "UPP", have been linked to multiple reports of fires, including one where a battery exploded causing fire damage. The CPSC urges consumers to stop using these batteries and dispose of them properly.
Specifically, the warning applies to the following:
What you should do if you own an UPP battery:
- Model U004 and U004-1: These are the specific model numbers being recalled.
- "Unit Pack Power" or "UPP" Brand: These batteries were sold under these brand names online and at certain retailers.
- Black, triangular batteries: They are typically sold as conversion kits to turn pedal bikes into e-bikes.
Why the warning?
- Immediately stop using the battery. .
- Dispose of the battery properly. Follow the guidelines of your local recycling center for damaged/defective/recalled lithium batteries. Do not throw them in the trash or general recycling bins.
- Contact the seller or the manufacturer: to inquire about a refund or replacement.
- Report any incidents: involving these batteries to the CPSC at www.SaferProducts.gov.
In summary, the CPSC strongly advises against using these UPP e-bike batteries due to the risk of fire and burn hazards, and urges immediate action to stop using and properly dispose of these batteries.
- Lack of safety certifications:
The UPP batteries have not been certified by an accredited laboratory to the applicable UL safety standards.
- Reports of fires and explosions:
Multiple reports have linked these batteries to fires, burns, and property damage.
- Manufacturer's refusal to cooperate:
The CPSC notes that the UPP manufacturer has refused to conduct an acceptable recall.
Several sellers do the same and it's almost true, when pinned down they will say the are all 18650, same size and maybe the same chemistry. In fairness he has stood behind his battries, and as others have confirmed 900 cycles for the price was pretty darn good. The maker of that brand is usually not very good about honoring their warranty. We lost lots of dollars standing tall and honoring the warranty, and nothing from UPPHe specifically states that the cells in his batteries are the same as used in Tesla batteries
Is this your new battery?Tom,
I was saddened to hear that Cali batteries have such a bad reputation . He specifically states that the cells in his batteries are the same as used in Tesla batteries . We live and learn. But that is water under the bridge . I will just recycle . I want to thank everyone for they're input . I am digitally challenged , but I hope that though this is responding to your post , that anyone following the thread will see that I appreciate all of the input . Thank you all .
Do not know the amp hours for the old battery. The motor is a Voila 48 volt , do not know the watts . I will look it up. They still sell that motor. Controller is 48 volt 35 amp 1500 watts I have bought a new controller , not here yet . It is 48-72 volt 45 amp 2000 watt , also a Voila . I have another post detailing that purchase.Is this your new battery?
https://calibike.com/product/electr...ium-li-ion-battery-and-charger-1-yr-warranty/
I breezed by the website and they state that their 52v 20ah battery uses Panasonic 21700 cells. So I do belive Tesla does use Panasonic cells. Though there's probably multiple variations.
That said at 52v- 20Ah that battery should be a beast and adequate. Do you know how many Ah the 48v one was?
What motor are you running? Do you know the watts? Same for the controller.. Specs?
Yes that my new battery.Do not know the amp hours for the old battery. The motor is a Voila 48 volt , do not know the watts . I will look it up. They still sell that motor. Controller is 48 volt 35 amp 1500 watts I have bought a new controller , not here yet . It is 48-72 volt 45 amp 2000 watt , also a Voila . I have another post detailing that purchase.
I also have a new post showing my current bike . I have become a posting fool .
One big key is to look at the sticker on the bottom of the battery, another is to look at the sticker on the charger. Charger output values are always higher than battery capacities. Just as it takes a pump more pressure to pump up while pushing down than the final pressure in a tube. Almost by 30% more. You need about 100 pounds of pressure down to pump up a 70 pound tube.Yes that my new battery.
makes senseOne big key is to look at the sticker on the bottom of the battery, another is to look at the sticker on the charger. Charger output values are always higher than battery capacities. Just as it takes a pump more pressure to pump up while pushing down than the final pressure in a tube. Almost by 30% more. You need about 100 pounds of pressure down to pump up a 70 pound tube.
