Archon X1 Programming Thread (questions and experiences)
I played around a little bit and was finally able to connect via VESC Tool to my Innotrace X1!
First I made connection using a simple USB to CAN adapter (e.g. canable) and tried to send common VESC CAN commands (VESC CAN-Bus Communication). I got no response and assumed it has been either completely disabled or hidden.. Its known for manufacturers that they wanna hide the fact, that they are stealing code: Here is another example, where a Torp TC500 controller has been torn apart. I gave it a try and brute-forced, by sending every combination possible... It took a few months, but one day, when I checked for my logs, the controller started talking back, because of one specific message I sent: 00D431FF # 14 78 00 00 00 00 00 00. It appears to be a "magic message", that enables usage with VESC Tool, once sent:
For connecting I used CAN-Forward on a VESC-Express. You can do the same thing with any VESC controller. I used a VESC-Express which is simpler, because it's powered by USB-C. It pops up as secondary CAN-device out of nowhere and it's possible to read and write motor parameters like maximum wattage, motor current, ...
CAN-connection is already available from the outside! Here is the pinout for the black connector (04R-JWPF-VSLE-S) of the M620-motor:
Code:
  │   │   │  ┖> x not used
  │   │   ┖───> H CAN-H ───┐    green
  │   ┖───────> G GND    [120Ω] is already in place!
  ┖───────────> L CAN-L ───┚    yellow
Code:
  │   │   │  ┖> x not used
That's a huge breakthrough , I suspect krasnador is gunna never show his face again now though !
Code:
  │   │   │  ┖> x not used
That's great news, well done! Does this have enough functionality to enable firmware to be copied from one motor to another? I bought one of the last (3000W) motors shipped by Innotrace and it has the firmware, that Krasnodar denied any knowledge of, which shows strange symbols for both motor & controller serial numbers as shown in @TPEHAK's post on page 13 of this thread (#224) & copied below. Krasnodar promised to update my firmware for me once, I'd sorted a cable, but he's not responding to my emails now! The firmware that I have allows me to make changes using the hacked X1 tool, but the controller does not react correctly to some changes, for instance, whatever I do, I cannot restrict power to below 750W. Thanks.
Hello, did you try to contact Krasnodar first for assistance? I would contact him first. Maybe ask him when he is planning to make the online server available again (he promised to make it available soon some time ago).
If he does not respond here is the link for the bypassed tool with advanced settings
Again: best, Top Dog info.
Archon is garbage. Everyone who has on EBR forum is asking for remedy.
I have Canbus 52V M620 ultra.
It is perfect.
Bwaaaahahahaha, when "Perfect" = weak kneed power-hog.
Right dude - while you emulsify your motors gears lube w/ detergent laden H2O.
Great solution. Replace what I wreck every year.
Previously it was '52v provides less range, blah blah blah'. Now yer a Fan-boy?
When were you wrong, then or now?
Gotta get yer BS straight.
Canbus blows. Entire planet says so. Barfang market control games. Weak and impossible (as yet) to upgrade.
Really super-dooper if you like 125nm max tho.
Carry on. BS is in. Don't be shy.
Fn'F
Do you know if it really has 3000W? The motor Innotrace sent me did not have 3000W power while I purchased the 3000W option (it had significantly less power). Krasnodar said the motor was flashed with production firmware. He updated the firmware, adjusted the power and assigned the numbers to the motor.
It was certainly not producing 3000W when it was delivered; my BMS was reporting that it was using 27 Amps peak (@52v nominal), settling back to 20 Amps continuous. Having played with the hacked X1 tool, I managed to get it to pull 55 Amps peak, but it was definitely not the "wheelie monster" that others have described although, to be fair, my current battery is not capable of delivering 60 Amps continuous, so it could be that that's restricting things.
The reason that I mentioned that it is supposed to be the 3000W version is that, according to the Innotrace website (before it disappeared) the 3000W controller was allegedly different, therefore, possibly running different firmware. Whether or not I actually received what I paid for is anyone's guess at this point, I did notice that, after my order was placed, the 3000W version was no longer available on the website, but whether that indicated that mine was the last one or that they realised that the cupboard was bare when they went to pick the controller for my motor is unknown to me!
As it's now possible for us to use the VESC Tool, I am hoping that it would be possible for me to copy the firmware from someone else's 3000W motor.
Code:
  │   │   │  ┖> x not used
Hello Dedo. Can VESC tool extract .bin fie firmware from the controller?
The original STM32 chip on my Innotrace X1 controller is dead (internally shortened 3.3v and ground pins). I guess the FET driver failure destroyed the chip.
I soldered new FET driver and STM32 chips and I need binary file firmware copy for STM32 chip to complete the repair. Infortunately I did not copy binary file from my STM chip before it died.
I emailed Krasnodar but he did not respond yet.
Innotrace X1 top board has 6 pads Tag-Connect interface for ST-Link programming dongle to flash .bin file on the STM32 chip.
I purchased a 6pins Tag-Connect with RJ11 plug cable and an RJ11 plug to pins adapter to connect the board to ST-Link. Now I need binary file to flash the new STM32 chip.
Ideally I need firmware adjusted for 3000W 52v 60A (this is what I had), but at the moment any Innotrace X1 firmware will work for me.
hi riders,
I am krasnodar from Innotrace. I am sorry that our internal company problems caused a lot of problems for our customers. this should not be the way how internal problems are handled.
in addition I was discredited and some things were reported by our company staff that are not true.
since a while Innotrace sold motors and controllers with controller hardware that was not subject to my quality control and software/firmware unknown to me. if you notice any problems with your motor/controller, please do not hesitate to contact me. our server had to be taken offline due to unauthorized access - making x1tool useless. work is still in progress to bring the server back online as soon as possible. up to this point of time I will be available here for any questions you may have.
please note that hacking x1tool software could lead to unforeseeable consequences, damages and loss of any support. also possibility of any firmware updates and further upcoming exciting features is not available with hacked software.
krasnodar
Hello Krasnodar. I need compiled firmware .bin file to repair my Innotrace X1 controller (please see the post above). I am not sure if you saw my email. Can you please send me a compiled binary file (.bin) for my Innotrace X1 controller adjusted for 3000W motor (52V 60A, 14S lithium battery with 60A continuous current BMS (80A peak current), 27.5" wheel size) so I can flash it on the new STM32 chip. (The top board version is X1_V2B Motorcontrol board (V2B Var02_UART S/N 000522) )
If anyone has Innotrace X1 controller laying on the table and willing to try to grab firmware and share it with me is how you can do it (I guess it will work only if the STM32 chip does not set in protection mode though. If it is in protection mode I think this way is not going to work. But maybe that magical message "00D431FF # 14 78 00 00 00 00 00 00" posted earlier here can somehow unlock the STM32 chip so you can read the memory, but I am not an expert here and I do not not how to do it).
Here is the tools list you need:
1) An ST-Link dongle (can be purchased here for example https://www.digikey.com/en/products/detail/adafruit-industries-llc/2548/6827110 )
2) Tag-Connect cable TC2030-MCP-NL (This cable and all further items below are to connect ST-Link dongle to the Innotrace top board 6-pads interface. This cable and all items below are optional, you can solder wires to the pads and connect them to ST-Link dongle. The cable can be purchased here https://www.digikey.com/en/products/detail/tag-connect-llc/TC2030-MCP-NL/2666489)
3) TC2030-CLIP (This clip fasten the Tag-Connect cable to the Innotrace board. This part is obsolete and hard to find. But you can use TC2050-CLIP and re-solder one receptacle to match the TC2030-MCP-NL cable interface. This clip can be purchased here https://www.digikey.com/en/products/detail/tag-connect-llc/TC2050-CLIP-3PACK/12318009 )
4) RJ11 to pins adapter ST-RJ11-R-BB (This adapter is to connect Tag-Connect cable plug and have convenient access to the pins. The adapter can be purchased here https://www.digikey.com/en/products/detail/schmalztech-llc/ST-RJ11-R-BB/23307380 )
5) 5 jumper wires (To connect the ST-Link dongle to ST-RJ11-R-BB. Bulk of such wires can be purchased here https://www.digikey.com/en/products/detail/digikey/DKS-20FF-20/17038802 )
Here is the process:
1) Connect ST-Link to the board following this diagram. You need to connect 5 pads (you can use the same cable and adapter I used or you can connect using different method. If you use the cable with adapter check the cable and adapter pins with multi-meter to make sure you connect the ST-Link dongle correct)
This is the Tag-Connect cable clip TC2050-CLIP I modified to make it works with the cable I used. I just de-soldered the receptacle and soldered to the hole closer to two other recepticles
Then Clipped the Tag-Connect cable to the Innotrace X1 top board and connected it to the adapter and to the ST-Link dongle following the diagram I posted above
2) Download and install ST-Link Utility application for PC. It will offer to install drivers during installation, install those too. Here is the official download of ST-Link Utility application https://www.st.com/en/development-tools/stsw-link004.html
3) Stick ST-Link dongle to USB in your computer
4) Launch ST-Link Utility
5) In the launched ST-Link Utility click "Target-->Connect"
6) Then click "File-->Save As"
7) Select ".bin" file format, name the file and click "Save"
1739417469799-png.189351
If it can not read the memory then there is protection. Then the only my hope is if Krasnodar will respond and send me the .bin file so I can complete the controller repair.
Or maybe this extreme method can work? https://embedthreads.com/hacking-and-reading-code-from-stm32-microcontrollers/
Found another shortage between 3.3v rail and ground. This time in the bottom board. I was thinking the rotary encoder board is bad and detached it but it turned out the phase "U" current sense amplifier AD8418WBRMZ has internal shortage between ground pin and 3.3v Vs pin. Placed order on new current sense amplifiers https://www.digikey.com/en/products/detail/analog-devices-inc/AD8418WBRMZ/4494754
Keep discovering the board.
Alright, great news, I think I fixed it. Just soldered a new AD8418WBRMZ chip, and the shortage is gone. So it looks like it is going to work. Now I need to repair the motor shaft (the current one wobbles and can hit the rotary encoder again). I am planning to use the new 15 teeth rotor with new second gear and hope the motor will work without issues.
Code:
  │   │   │  ┖> x not used
I made a cable for VESC Express. I do not know how those connectors on the VESC Express side are called (I do not remember where I found them) but the end on the Bafang connector side can be made out of these parts
Guys, the reverse engineering of the Innotrace X1 controller is almost complete and almost ready for public release so anyone can order parts on JLCPCB or PCBWay for cheap and start tinkering with it to have nice smooth controllable 3500W power, using it to repair their controllers in case of failure (like what happened with me) and do another fun stuff. But we need your assist to do final tests - we need to extract the original firmware from the original Innotrace X1 controller bit by bit. Ideally we need different firmwares with different settings since it looks like not each firmware is compatible with the bypassed X1 Tool utility.
The firmware needs to be extracted from the STM32 chip on the controller, so we need persons who have controllers and know how to do this. Feel free to contact me if you are able to extract it. About the firmware extraction methods I posted in this thread earlier.
Guys, the reverse engineering of the Innotrace X1 controller is almost complete and almost ready for public release so anyone can order parts on JLCPCB or PCBWay for cheap and start tinkering with it to have nice smooth controllable 3500W power or do another fun stuff. But we need your assist to to final tests - we need to extract the original firmware from the original Innotrace X1 controller. Ideally we need different firmwares with different settings since it looks like not each firmware is compatible with the bypassed X1 Tool utility.
I think a lot of people have lost interest in these bikes due to the non existence of support. I know I have. My frame and motor are up for sale. I also have an empty battery case I got directly from Dengfu. I’m going with the HPC Trailblazer Fat Bike that was just released.
Yeah, exactly, and we are about to open source this controller, we do not need support anymore. Enough is enough!
I have finished reverse engineering of the controller! The files format is KiCAD. It has complete reverse engineered schematic and PCB with all the components and complete information about circuits and sensors including the BAFANG M620 UART motor sensors and wiring harnesses.
Here are the KiCAD files (Gerber files for the PCBs fabricating are also can be found in this archive, those already have necessary format for JLCPCB or PCBWay) feel free to use it
Here are the files for 3D printing. I recommend to use ABS with 100% solid infill. The first part is "Standoffs spacer.STL", you need 2 of those. You have to place those parts under the plastic standoffs to have proper spacing between the PCBs. The second part is "VESC Encoder Bumber V0.03.STL". You need just one of it. This part is to protect the rotary encoder chip from mechanical impact of the motor shaft could happen. I recommend to glue that bumper with a couple dabs of E6000 glue so in case you need to remove the bumper you can just apply some heat with a heat gun to soften the glue and remove the bumper.
Here is the PDF file with vector graphics you can use to cut the bulk capacitors isolators to prevent the possible shortage. You can laser cut it out of 1mm thick copper free fiberglass sheet
You can use it to diagnose and repair your controller, or use it for reference to make a new improved version, or use it for educational purposes, or use it to fabricate spare parts, or use it to make it for any other purposes, and most importantly, use it for further VESC firmware developing! This controller is basically a VESC controller.
Benjamin Vedder made the firmware for this controller. Unfortunately I was not able to make this firmware works (I am not familiar with VESC stuff, the motor did not react on throttle and the display showed error 30 (no communication) after I flashed the firmware and and applied display lisp file and the motor config xml file. Here are the VESC firmware files for this controller. If you want to build the controller you can to try this firmware and post here the results and details of how exactly you made it works in case of success.
Here are some notes:
The AMPLIFIER board is 1.2mm thick 3oz copper (external layers) board with blind vias.
The ENCODER board is 0.6mm thick 1oz (or 0.5oz if you want to) copper board with castellated holes. You can use just regular process to keep this board cheap, but you need to remove metal burrs with sharp blade in this case after receiving the board.
The BRAIN board is 1.6mm thick 1oz (or 0.5oz if you want to) copper board.
I would recommend to use JLCPCB Service for the ENCODER board and for the BRAIN board. For the AMPLIFIER board I recommend PCBWay service. I also recommend to order a stencil for the AMPLIFIER board. The BRAIN board and the ENCODER board can be soldered manually.
I implemented some improvements over the original design. Here is the list of some:
1) Fixed the rotary encoder interference (specified thinner PCB).
2) Implemented a 3D printed bumper for the rotary encoder mechanical impact protection (I believe the rotor impact on the encoder damaged my controller).
3) Fixed the AMPLIFIER board holes misalignment (The Innocence AMPLIFIER holes have slight misalignment with the motor mounting holes which could potentially cause issues).
4) The rotary encored chip now perfectly aligned width the motor rotor axle (The Innotrace controller has some misalignment here).
5) Some edges of the AMPLIFIER board were shifted outside to add material around the circuits and improve mechanical integrity of some holes.
6) Some elements on the AMPLIFIER board were shifted to avoid mechanical interference and possible shortage or damage.
7) Some traced on the AMPLIFIER board were modified to avoid possible shortage with the fasteners.
8) The footprint for the MOSFET driver chip was modified for easy manual soldering and for reliable bottom pad soldering with improved thermal conduction and better cooling of the chip.
9) Implemented helpful silk screen information.
10) Added a USB-C receptacle.
11) Added a Molex connector for easy connection to ST-Link to ease flashing firmware.
12) Added a circuit with powerful source of 5V for VESC Express
13) The controller wiring harness connectors were spaced better to avoid mechanical stress on the connectors.
14) Increased thickness and rigidity of the BRAIN board to avoid mechanical stress on the soldered joints while handling the board.
15) Added copper thieving on the AMPLIFIER board bottom for better thermal conductivity to keep the controller and the MOSFETS cooler and to avoid board warpage and copper deposition issues during fabrication and assembly process.
16) Removed some unnecessary circuitry
17) Implemented 3D printed spacers for the plastic standoffs for proper spacing between the PCBs without bending and stressing the BRAIN board PCB.
18) Implemented the bulk capacitors base protective covers made out of thin fiberglass sheet to prevent possible shortage
If you are satisfied with the work of Benjamin Vedder please consider donating for his effort here making sure he knows what he was donated for.
Here is how you can connect VESC Express to VESC for Bafang controller.
Here is the parts list:
1) Some PHB 2.0mm crimping terminals (you need just one). Can be purchased as a part of a set here
2) One JUMPER SWPR-001T-P025 X2 12" or JUMPER SWPR-001T-P025 X2 10" wire (part number AJWPFJWPF22K305R or AJWPFJWPF22K254R)
or https://www.digikey.com/en/products/detail/jst-sales-america-inc/AJWPFJWPF22K254R/9865957
3) Some marine adhesive sealant
4) Maybe also order a plug replacement part number 04R-JWPF-VSLE-S in case you damage the original plug during the process (if you know how to extract terminals from 04R-JWPF-VSLE-S plug without damaging it you might not need it).
Prepare the Bafang m620 UART controller harness and the crimped wires
Stick a pick tool near the CAN plug wires and puncture the seal through
Stick a rode or a tube with about the wire diameter from the opposite side through the opening you did
Cut one crimped end of the crimped wire off and stick it from the top side of the seal
Alternating pushing and pulling the wire and the rod make the wire go all way through the hole
Move the seal on the CAN connector off the plug sliding it on the wires. Stick a small diameter pick tool from the back side to open the latch and pull the white plug off
Stick the crimped wire terminal end to the seal opening and attach it to the last free opening in the CAN connector
Close the seal
Route the opposite end of the new wire through the harness. You can replace the zip tie doing so if it is too tight
Remove the silicone from the opening on the CAN plug on the controller side of the harness (marked yellow, green, blue)
Mark the wire to necessary length, trim it, strip the end for crimping and crimp the PHB terminal on it
Stick the terminal into the remaining opening in the plug
Apply some marine sealant on the back side of the plug
Wait until the sealant is dry and now you have 5V power source for the VESC Express. I did not test it yet but in theory it should work (for some reason mine did not work when I connected it to USB. Maybe this should make it works. Too bad VESC does not provide clear instructions for their products)
Here is how to make the wiring harness for VESC Express to connect it to the controller wiring harness
I prepared the files for 3D printing you need to print for the VESC for Bafang m620 UART controller. I recommend to use ABS plastic and 100% solid infill for the parts.
The archive with the parts can be downloaded here
There are 2 different parts.
The first part is "Standoffs spacer.STL", you need 2 of those. You have to place those parts under the plastic standoffs to have proper spacing between the PCBs. I also recommend to use these spacers for the original Innotrace X1 controller if you are planning to disassemble it for some reason. The original standoffs are too short and causes the top PCB bend which can cause damage. The VESC for Bafang m620 UART controller BRAIN board PCB is thicker than the Innotrace X1 controller brain board so those spacers is a must for the VESC for Bafang m620 UART controller.
All other parts (fasteners, wires, standoffs) are the parts from the original Bafang m620 UART controller so you do not need to purchase those if you have the motor with the original controller.
In case if you want to put a bumper on the original Innotrace X1 controller here is the STL file for 3D print. The bumber for VESC for Bafang controller and the bumper for the Innotrace X1 controller are different.
