The more I ride it, the more I like it.
jobtraklite
West central Illinois on the Mississippi bluffs.
I thought I'd introduce an ebike that I haven't seen mentioned on EBR, or any forum for that matter.
A while back I had a bike wreck, the result being nasty road rash on my knee that didn't heal. The wound doctor I eventually went to kept me off my bike for several weeks. I needed some entertainment while I was grounded and naturally spent the time studying ebikes. I came across a strange YouTube review of a Funhang, a brand I'd never heard of - one of the many youtube reviews titled "The cheapest -- ebike on Amazon", this one "Amazon's Cheapest E-Mountain Bike".
The reviewer spent the first third of the review worrying about his house burning down. He took apart the battery to check the cells, but couldn't find anything wrong with them. So he put the battery back together with duct tape and proceeded with the review.
Now the bike has just about all the features one would look for in a $1000 - $1500 ebike. But the reviewer didn't think much of most of them. For example, he said the pedal assist seemed to kick in and out randomly, and complained that the tires were made of peach fuzz. But as time went on, he seemed to become more positive. After surviving a very rough and scary down hill mountain bike trail he began to recommend it.
There seemed to be hundreds of youtube reviews of the Funhang brand: step thru, mountain bike, and fat tire. Some seemed professional; but most were very amateurish. All were positive. The only actual user reviews I could find were on the Amazon ads for the bike. Almost all were positive. Now I wasn't born yesterday; but I don't see how a manufacturer could conjure up over sixty positive reviews among about 2 or 3 negative ones.
So I thought what do I have to loose and purchased the step thru version for $329 + $100 shipping for a total of $429.
The approximately 3 week promised shipping date seemed a bit long. But it did arrive 4 days before promised; so I can't complain. The box arrived with no gashes or gauges and the contents were well packed. Nothing was damaged or missing. Assembly was about average for DIY ebikes. I did have a bit of trouble seating the front brake rotor. But I think that was due to my having something backwards. Once I got it straightened out, it came together nicely.
I won't go into all the features; the Amazon webpage does a nice job of explaining them, and everything seemed to work perfectly. I'll just mention a few things that struck me.
Build quality - I'm not an engineer or metal worker; but the build quality looked great to me.
The ride - super smooth, nimble, comfortable, and solid.
The seat - It's a seat, about the same as most - OK in the beginning of a ride but as the miles accumulate my boney bottom began hurting.
Pedal assist - I haven't been able to completely understand yet the pedal assist. All I can say for sure is that if you select the right PAS level and gear, you will get what you want. For a given PAS level, leisurely pedaling seems to take you to various speeds depending on the choice of gears.
Twist Throttle - I had to chuckle about the twist throttle. It seems to be a general rule on ebike forums that only thumb throttles are politically correct. Normally, I hardly use the throttle. But my wound doctor eventually let me back on the bike, but allowed no peddling, only the (thumb) throttle. After a while my thumb became sore. So I'm happy to go against the thumb throttle rule. I should note that, unlike the pedal assist, the throttle cuts off depending on the peddle assist level. For example, it cuts off at 6 MPH if pedal assist is set to 1 and at 9 MPH with PAS 2.
Front Disk Brake - Early on I did experience a ticking in the front disk brake. Getting up to speed and locking the brake for a few seconds performed whatever adjustment was required.
Adjustments - Amazon stresses all the adjustments available to dial in a good fit for someone 6'1" or smaller. You've got the seat post height, seat angle, seat forward and back, adjustable stem up and down and in and out, and finally the handle bars up or down. It took me so many tries to get it just right that I began to wonder if all this adjustment was a negative feature. But once I got it right, I was very pleased with the result. As a side note, I hate the threadless stems that have no flexibility at all.
Weight - some reviewers complained that it is heavy. They are only announcing that they are ebike newbies. I didn't put it on a scale; but the touted weight of 55.8 lbs seems about right. That puts it in the middle range of ebike weights, or below it, considering the typical ebike with these features often advertises more than 60 lbs.
Range - the bike claims a 40-50 mile PAS range which is enough for me. But I wondered, considering the Funhang's 48V, 7.8 AH (374.4WH) battery. For comparison I also have a ride1up Turris with a 14AH battery that touts a 30-50 mile range.
I finally got a chance to do a bit of testing. I took a 24 mile ride on a flat rail trail in Central Florida, no wind, no throttle, exclusively PAS level 1 at 10-12 MPH. When I finished the 24 miles the voltage reading was 47.5. Assuming the max voltage at start was 54.6, LVC of 39 volts, and I were to ride the same the rest of the way, then I estimate a range of 52.7 miles. Other parameters such as terrain, trail condition, my weight, luggage weight, tire condition, etc remained the same. I don't know what the margin of error, as the media types would say, is. But I'm confident I could get 50 miles before the voltage dropped to 39.
Long term reliability. Obviously, I can't say anything about this. I only hope that it lasts until I'm too old to ride (I'm 83). As much as I like the Turris, I like the Funhang just as well at about 1/3 the price.
Update June 4, 2025.
After about 900 miles, the title of the review "The more I ride it, the more I like it." still holds.
I refer to this bike as my Florida Funhang. When I returned to Illinois in May (i'm a snowbird), I purchased another EB-C1 and refer to it as my Illinois Funhang. It also arrived without a single defect. It also has one improvement. Several reviewers noted the pedal assist lag, which I noticed also. The pedal assist on the Illinois Funhang kicks in after about 2 pedal rotations, which is considerably better than the Florida Funhang.
The price on Amazon had increased $20, still well worth it.
UPDATE July 1, 2025
In case you are looking for a backup battery, here is the scoop. I wanted a 48V 13Aah second battery for my Funhang EB-C1 and scoured the internet with no luck. So I contacted Funhang via support email. I phrased the question as "What should I be aware of when trying to purchase a backup battery". They replied "The mold used for this battery is custom made, (proprietary) so there is no compatible battery on the market. If you need a 48V13Ah battery, you can buy it from us.
I asked how? and how much? They replied $100 and send it to their account at PayPal. And they asked for a delivery address. They responded "The battery has been shipped from China. It will take about 20~25 days to send the package to FedEx in the US. Then, FedEx will fulfill the remaining delivery once it receives the package. The logistics will be updated at that time. The tracking number is xxx".
Like some of you, I worried that a $100 48V 13Ah battery was too good to be true. But this was Funhang who had already sent me two fantastic bikes in perfect condition. So I bit. The battery arrived more than a week earlier than promised; and, as with the bikes, it arrived well packed. I slapped onto my bike and off I went. No tax, no tariff.
I haven't had a chance to test the range yet.
A whole bunch of Funhangs for under $500 shipped on Amazon, like this one.
Well, there gotta be thousands of similar bikes in every small city in China. People ride them. A bike is a bike. A tour guide told us once that a small city in China is about a million people.
Thanks for the report. Hope the bike keeps treating you well!
The exhausted battery voltage should be more like 42V, maybe 41 and change, I think. My guess on the ebike's range would be more like 40 miles.
I've been checking my ebike mileage for years on over a dozen different bikes/motors/batteries. I won't bother you with the nerd stuff,
Yeah, if he gets 24 miles first the first half of the battery, then 16 miles for the rest is possible. That's pretty good for a 48V7.4AH battery, about 300-320 useable watt-hours.
Thank you for sharing your detailed and thoughtful experience with the Funhang electric bike.
I finally tested it. The last voltage bar disappeared at 44.4 volts. I was about 3/4 mile from home; so I kept going. The assist didn't cut off; in fact after a while the last voltage bar reappeared for a short while. The voltage fluctuated between 44.4 and 43.6 until it finally died at 44.3.
So neither of us were correct; but you were closer.
A question: would it be correct to say that the LVC does not depend on the battery's aH? Rather the aH would determine how far it would go before reaching the LVC?
I can't really answer your question precisely; maybe someone else can. Although, as I understand it, LVC is generally based on voltage, and as amperes of current (electrons) flows out of the battery the voltage also gets low enough eventually to cause the cutoff to stop the flow so as to preserve the battery. The cutoff on my ebike doesn't happen until the battery is below 43V, somewhere around 42.X volts. So it would seem that different mfrs design their battery management systems with different parameters.
LVC is the voltage the bike shuts down to protect the battery.
There are two.. One in the battery, the other in the motor controller. Typically set around 40 - 41v on a 48v battery
Ah is the amount of stored power. Generally higher Ah batteries will have greater range and lower voltage drop on hills and when used with high power motors. The trade off is size and weight so bigger isn't always better especially if you're not using it.
You speak from personal experience? :D (You walked right into that one, LOL!)
You try carrying around a third leg...
After a while being called tripod isn't funny anymore, especially when the ladies scream bloody murder. 🙃
Oh, well that explains why you're not using it any more. 😉
Well technically that's true... but you'd be surprised at the amount of talent out there that's capable.
I guess your Mrs.'s was able to walk it off after all... 👍
The price on Amazon had increased $20, still well worth it. Κάνοντας συνεχώς υπολογισμούς για αυτονομία, βάρος και πραγματική αξία, σκέφτηκα πόσο παρόμοια είναι αυτή η διαδικασία με τους υπολογισμούς καθαρού μισθού στην καθημερινή ζωή. Την ίδια πρακτική προσέγγιση ακολουθούν και αναπτυσσόμενες εταιρείες όπως η PUNIN GROUP στην Κύπρο, που δίνουν έμφαση στη διαφάνεια και στο τι πραγματικά παίρνεις στο τέλος.
UPDATE July 1, 2025
Nice write-up! Sounds like you really put it through its paces and didn’t just ride a couple of miles. The range testing and actual delivery timing are super helpful to hear. Makes me feel more confident about considering one for myself.
