Winter riding on the Zen Photon.
As far as getting summer/wheels made -- I had the same thoughts. Means we'd need another enviolo heavy duty, though, right?
I wonder what the cost of said wheels might be. I got tannus armor and tube for mine also. Looks like mail is starting back up shortly so tires will be coming my way, finally.
Guys, I'd start by asking the folks at Zen about buying a spare set of wheels. That way you know they will be 100% plug and play. Be ready for a bit of sticker shock, I think the rear hub alone is several hundred in Canada.. The tires would have to be pretty awful to swap for me to go that route. Do your rims not have the concave middle section to tuck the tire into when mounting it? This can make a huge difference in bead clearance.
...I'm positive the cost is a little rich for me right now -- but if the swap is that gnarly to do twice a year -- Maybe I pay a shop to or get plug and play wheelset as you said.
The fit was super tight.. I had a hell of a time removing and mounting the tyres.
I'd love to see a Zen Fat bike with belt drive for the Canadian winter.
I take it the skinny tires are a bit challenging, are they? Still waiting on my 2.6", but there's hope yet...the mail is running.
Have ridden on fat tire ebikes in winter. It's good fun, and would be better not having to try and oil the chain at -30. We're in for yet another frigid blizzard here today.
Well.. the Ice Spiker was awesome on ice... but snow was difficult lol. I think you need 4" or more for snow.
Indeed, this is exactly as expected. ICPs work best on ice and smooth hard packed snow (and probably no other tire is better in these conditions), and 4-5" "fat" tires (something like the 45nrth Wrathlorde/childs) are needed on deeper soft snow and uncleared trails that have a mix of conditions. The more you are riding on hard surfaces (paved/gravel trails or streets) the narrower you can get away with up to a point that depends on temperature.
Even after the road is ploughed the cars churn up the surface if there's an ice melter being used, and then you end up with piles of "brown sugar". If the temps don't go low enough to fully freeze this type of surface overnight you usually can get away with narrower (<2") studded tires that get down to the hard road surface. If however you have the mix of brown sugar and ice pack with icy ruts then a mid to fat (2-4+") studded tire is usually better than a narrower one. In cities with lots of car traffic and the surface doesn't have too much ice build up (more wet slush) then an even narrower studded tire can be a good choice due to it's much lower rolling resistance.
In general for commuting in suburban and urban areas where you'll see a wide variety of winter conditions I think a well lugged and studded 2-2.5" winter tire is probably the best choice when you have the luxury of avoiding the worst conditions (newly fallen really deep snow). If you have to commute even in the worst conditions then the heck with the compromises and it's fat all the way with a big battery.
In this city/Saskatoon, we've had huge temp swings, and we're pretty awful for snow clearing on roadways. Everything is sheer ice and snirt right now with a new layer of really cold snow. A week of extreme cold warnings. Can confirm, this is probably best handled by low pressure fat tires. But still! Mine just started moving within the mail system so I'm likely going to find out.
So. I have found out. I agree, getting that last 20% of the bead on and seated was incredibly hard -- but did you also try doing it with tannus armor?(I did) what a brutal experience(talc helps in the tire a lot, didn't do it in the first tire and I have regrets..because I may be redoing it shortly). In future I think I too would consider a second wheelset.
A few more adjustments yet, but I'm almost winterized.
One major thing to note: 2.6" Schwalbe Ice Spiker Pro's DO NOT fit with fenders. Specifically the rear, front seems fine. Removing that wasn't much fun -- I zap strapped the rear light cable(which normally is routed through the fender) to various parts of the frame as a sort of temporary winter mode. Velcro would probably be better for next season.
Heh, really a studded wheelset in 2.4" would be about perfect if it existed.
Yep, I and I think a lot of other folks would for example love to see 45nrth offer the Khavas with a little more width (currently they are 2.1"). While there are a lot of bikes with 40-50mm/1.5-2" tires It appears that there are also quite a few that can handle 55-60mm/2.2-2.4" tires.
@DrewInSK: Are your wheels 27.5"?
Why not Ice Spiker Pro 27.5x2.25"?
You might say you wouldn't like riding narrower tyres. What I say is 'You won't regret it". Bear in mind these tyres are very special and different to anything regular. The actual contact with the surface is done via the studs only! As you might notice anything else in the tyre is totally slick!
Of course, these tyres will not ride through deep snow but they can be safely ridden on ice (even on a frozen lake), proven!
I regret your wheel size does not allow installing Schwalbe Marathon Winter Plus, which are a way more normal tyres but the traction on ice is excellent, too!
I went wider because as far as ebiking in winter in Saskatoon, fat studded has worked well for me in our most common conditions(though those were 3-4.8" fat tire ebikes at lower pressures). SO I figured I'd roll the dice on 2.6".. I still think this was the right move, though right now at -30C-ish I'm not so motivated to get started just yet. I wear ski pants usually anyway so the dirt isn't a big deal from the rear(plus i'll have partial coverage thanks to my trunk).
I have the 27.5x2.25, they worked great. It's best on ice, thin snow, and packed snow. As long as the studs can make contact with a hard surface, the tires will grip. I feel super confident on my winter commute.
How much did they say for a set of complete plug and play set of wheels?
Finally got the upgraded display and had a chance to re-arrange the cockpit to my liking and get it installed. I don't use throttle...ever really(and can still reach in a pinch if I need to), but it's handy for maintenance I suppose. I found the lack of good placement for a bell was really bugging me also. it's ready for a good ride in the snow we're going to get tomorrow. Probably not the last we'll get, either. And then soon the spring riding season will begin. I'm pumped for it, especially now that it's all adjusted just so. No whistles, nothing to interfere with the good times.
@DrewInSK, did you order your new display from Zen? I'm asking because my wife has the older stock display on her Photon and doesn't like it. She finds it hard to read in bright sunlight.
Sure did yeah, it came up in another thread...I think the one for the latest version of the Photon. Reach out to them about it. I haven't put it to the test in full sunlight yet, and I doubt we'll have much today.
Part of the problem with any display in sun light is having it lay flat as it does over that ridiculous Zen stem. You'll find if you have it mounted more vertically they handle the sun much better.
Mounting the display on something like this makes a world of difference.
Good advice! Thanks for the link action too. I tend only to glance at it anyway for speed and PAS level. My use case was the better cockpit config(and pogies, though the extreme cold has since passed).
