1000w 36v jackal dirtbike
jiry
Europe
It wont drive when i putt up the wheel it go's buth not on the road what can it be ? Battery ? Ecu ?
When an ebike powers up and doesn't run, but will spin its wheel when off the ground, that is often a sign of a weak battery. It has voltage, but not enough curremt.
Looks like +12V lead acid batteries on your bike. If so, an automotive shop or battery store knows how to load test them.
For something like a bike, lead acid is relatively cheap, but heavy, and has short life.
OK thx verry much and indead its the lead 3x 12v 36 v outcome buth i mesure the 38v outcome buth what would be à good replacement option lipo ? Its too much money buth dont want to buy in 6 monts New Again
This an option ?
That's a terrible option. That battery is too small to have 30000 mah (30 AH). Means the vendor is lying.
When you get into lithium, the cheap stuff catches on fire easily, so you have to spend some mpney.
It's also the wrong voltage and you don't know if the bike controller can take 48V.
I can't tell you what to buy, You're in Europe anyway.
OK thx verry much i try to find best option gellbattery beter for life of battery or best thé same Lead ?
