My step daughter bought one of these REI bikes last year when the went on sale. She really likes the bike except for one thing. She has MS and the bike does not have a throttle, it's a class 1. She needs the throttle to help start off from a stop so I offered to see what I can do with it.
I've built 3 ebikes so far for myself, all recumbents with mid drive motors. This bike uses a 36v 350w bafang hub motor along with hydraulic brakes. It's a decent bike considering she paid 700 for it when they went on sale. I picked it up yesterday and started some exploratory surgery on it today. I got the controller out from its tight little hiding spot, it's a bafang branded controller that I cant find much information on .
I'm not looking to spend lots of money upgrading a 700 dollar dept store ebike. It's not a bad bike considering. Has hydraulic brakes and a name brand hub motor. As for the torque sensor, that can just stay where it is, I can add an external PAS sensor. I asked her last summer if she knew what she had and she didnt have a clue.
What I'm looking for is some type of controller I can swap in for the existing box that will work with the existing bafang motor without any problems. Current controller is rated for 15a at 36v. If I have to start cuttin and splicin I can do that, though it's not the first choice. If I can fit it in the existing space, thats fine too, otherwise I figure out a spot to mount it outside. I'll also need a matching display and the new PAS and throttle.
I do wonder if it is worth opening up the OEM box to see if there may be some terminals or unused connection for a throttle switch that was not used to keep it as a class 1. Sorta like the Tongsheng mid drive controllers that could be hacked to hook up a throttle.
The bafang hub motor:
The controller out of its hidey hole:
9 pin connector to the motor:
The existing connections. The one with the two larger terminals is battery. I think the lavender is the torque sensor and the last is the display and brakes
