I have a 8fun bbs02b thats been fitted for three to four years never had any problems until now, Never use the thumb throttle but I did fit it and that works fine but now when I pedal the motor cuts out and then back in continuously.It has got wet a lot lately! So I wondered if this could be the problem, No gear change cutout fitted and I've checked all the connections and they're dry not and corroded. Do you think this is likely to be the motor controller? Does anyone know how a mid drive pedal movement is detected? I presume this would be separate to the controller? Thanks for looking!
