This is a question for the knowledgeable EBike Bafang BBS01B owners.
CanNik
United Kingdom
I have two bikes with this motor and the same display.
They have both been set up differently, not by intent. Just that the fitter/supplier fitted it, set it up and they are both different.
One is faster, and more powerful in the gears and power settings than the other.
e.g for one at power level one in GEAR 2 of 8 the other to be "similar" would have to be on power setting four
My question is that I have a laptop, the lead see image, what do I need to do, to "look" at the settings on the "in my opinion" better set bike, to note the settings and do the same on the other bike.
Software download ?
Many thanks.
If you have an android phone.. This easiest way to access the settings is using the SPEEED AP.
Read this for an explanation of the settings.
Here is the software for a pc. I believe there is an updated version with slightly better visual but functionality is the same.
And another way to connect to the controller is here...
Here is the pc software v2.2b
... but again the android ap is the easiest of all to use.
And some more reading.
PRINTED OFF WITH THANKS
