Two Month Review Of Cervelo Rouvida Rival Road Ebike
jtheat
Two Month Review on Cervelo Rouvida Rival Road: It's winter here in northern California, so limited riding, but still got in 500 miles. I live in the foothills of the Sierra Nevada Mountains at 2700 ft elevation, so most of my rides are 100'/mile of climbing. Most rides in winter are 25-40 miles, 2500-4,000 feet of climbing. All hard surfaces. Bottom line - I love the bike on every level, met all my requirements for specs. The geometry has a fairly short wheel base, so it is very responsive but not the least twitchy. It carves corners on the mountain downhills with a real sense of the road. Feels like a carbon analogue bike. Uphill is very comfortable and the motor is supreme... more on that later.
The light weight motor/battery and where it site in the frame is very balanced. I am 5'7" and the medium size fits me perfectly. I am usually a bit small for a medium, but I'm very happy with the fit. It's a relaxed fit with a great cockpit. The carbon aero bars are awesome, I love the flat top platform. The motor controls on the drops are easily reachable with the thumbs of my small hands when I'm on the hoods. All the specs on the components are a good match for the bike. I can't believe the Red version is $3k more just to add carbon wheels, high end saddle, and upgrade from Rival to Red. This is my first 1x bike - always rode 2x compacts, but the gearing is almost identical range with the 10-44 12 speed cassette. The key is the 46t chain ring, it makes the range work. Most 1x road bikes have 42t or 44t, so the 46t makes it all work for me. It's fast on the downhills and plenty of low gearing for the uphills. I routinely ride 8-12% grades and the occasional 20-24% with no problem. Very stable in all conditions. I am enjoying the 1x and don't miss the front derailleur, and the gearing gaps are not an issue at all. Maybe if I rode in a peleton the cadence might be an issue, but with an ebike, I enjoy the simplicity. The tires are 30mm, and this is only thing I would change - I have 32mm on my Synapse Neo 1, and it's a bit more forgiving. But - the 30's are fine and give more of a road feel.
On another note, if I compare this 28 lb Cervelo to my old 40 lb Cannondale Synapse Neo 1, it's like comparing a Porche (who actually owns Fazua motors) to my Dad's '63 Chevy Impala. They both get you there, but one is pure fun, the other is soft and cushy!! The only other change I made is the saddle - I put on my favorite Avatar 143, but that's just my old bones talking.
As far as the bike's detailing - it is first class. No exposed cables, elegant lines, everything in the carbon frame is beautiful and designed with total integration. I'm an architect - I think it's a work of art. Everyone I meet comments on the clean lines and look. Plasma Blue color is also a winner.
Now.... down to the motor. The Fazua Ride60 motor met my pre-purchase desire with 60Nm, 450 W max, 430 AHr battery. It does not disappoint. There is plenty of power at all levels and I really like the Fazua app for creating custom power profiles. I have used the standard default setup, which is a bit toward the more powerful side. I created lower power setups because I often ride with acoustic bikes, and don't want to just ride away from my friends. The higher power level setups I use when I'm riding with other ebikes and we just want to go fast... it does fast without problem. So much fun!! For mileage, I have gone 45 miles running in the River #2 power level, and pushing it pretty hard in the mountains for almost 3 hours, and used 85%. I feel if I run in the lower power level with modest support, I can probably get 60-70 miles no problem, and in the mountains. I came from a Bosch motor on my Synapse Neo, and the Fazua is superior in my opinion. It is much quieter, the bike feels like a real bike with me just being stronger! It is seamless when I pedal, stand, go over 28 mph, always. The motor noise is almost non-existent. Unlike the Bosch. The only thing more the Bosch has is 4 levels vs 3, but I don't miss it. The Bosch motor feels like a motor on your bike, the Fazua is almost transparent - just you pedaling a bike. I really like the Fazua app, and run it on my phone on my stem holder. It shows the usual speed, distance, time, cadence, battery % but also shows rider power and motor power output in an easy graphic. It also shows power level by the color of the power display (green, blue, red). Well thought out. Very nice app. Creating custom power set ups is easy.
Final note, I have not used the gravel bike drop outs and don't plan to, I'm a roadie.... So, hope you enjoyed my review and I'll update as things move forward, Keep on keepin' on!
Thanks for that very nice review. I've had my Rouvida only a week, and one gravel ride. I'm 5'8" and the medium is great. I bought the GRX gravel version, but customized it, with the assistance of my great LBS, to a mullet setup with Rival AXS up front, a 42t chainring, and Sram AXS Transmission (10-52 cassette) in the back. I also had some entry Enve G25 wheels I moved to the bike.
I'm in the mountains of western North Carolina, hence the gearing, but I have a similar setup on my other bike. I'll try to post more about the ride as I start spending more time on it. My first e-bike and I was surprised (at existing settings) how much work/exercise I got at any level of power. A good thing and important to me. I rode it 2/3 of the route without power to get a feel for climbing without assist.
Excellent so far, and as a gravel model (though they are interchangeable) mine is the "granite" color which looks great in-person.
Hi, this Is one of bikes I’m interested in to use on the road, learning more about this bike an in particular about the bikes range would be very helpful.
p.s my group rides are mostly between 50 and 60 miles with an elev gain 2000 ft approx
If you ride in Green mode, you should be able to do that distance and elevation no problem. I've done 50 miles and 5000 ft. I've also created rider profiles for better mileage when I have long rides. I think 75 miles and 6000 feet is doable with care.
This ride was done on about 50% battery.
My experience after about 2500km [1500mls] is now consolidated for 750 mt [2400 ft] elevation gain for each 20% of battery . Breeze assistence at 90watt for 130 watt raider,River assistence at 210watt for 200 watt raider,Rocket assistence 300 watt for 150 watt raider.
Enclosed the report for a tour [ 90km + 1500 mt elevation gain ] and 35% battery consumption.
I'm 70 years old ,177cmx 75 kgs and a year mileage around 10000km [6500 mls].With Rouvida is very easy on flat to ride over 30km/h [ our bike in EU are limited to 25km/h] without support and even more if within a group.
My previous bike was a BMC Roadmachine Amp01 with Mahle X20 [ also a very performing bike] but the support on steep climb FazuaRide60 offer is more consistent. With Breeze till gradient of 12-13% ,River above ...Rocket never used
My previous bike was a BMC Roadmachine Amp01 with Mahle X20 [ also a very performing bike] but the support on steep climb FazuaRide60 offer is more consistent. With Breeze till gradient of 12-13% ,River above ...Rocket never usedView attachment 176395
Great report.
Interesting where you ride. I'm coming with friends to the Dolomites next year for a week long bike tour. I'm hoping I can rent a Rouvida the for my riding. I'm 72 and enjoy the help!
I missed this post when it was made! great to hear some first hand reports on this bike.
Great report.
For sure You&friends shall enjoy the Dolomites, very nice surroundings...I should be doubtful about the possibility to rent a Rouvida ....here in Italy Fazua ,for the time being , only available for the so called light-Emtb...The e-road & e-gravel are mainly Mahle X35/X20, TQ50, Polini EP3+,Bosch....
Maybe a Pinarello Nytro with a TQ50 motor would work.
This 'use case' for an e-bike just warms my heart! There are so many cyclists young and old that merely assume that "e-bikes" are more motorcycle than bicycle.
I have been for many years a road cyclist with a quite consistent mileage [ 12k-14k kilometres p/y] and I can assure the global mentality is not really too wide....I would say very much conservative or even better thick headed...
Due to health 's problem I switch to the e-road bike and I can guarantee that even if the support is there , during strong and long climb in low assistance the work-load is quite relevant....but the hearth range not longer in a red zone or better to say , possible to better control ...My red line is at 150 bpm and generally speaking my standard average is within 125-130 ...
I've logged 1200 miles in two months on my Rouvida. I'm 71 years old and ride in the Colorado mountains. I only weigh 135 pounds or less. I use the bike's power meter without assist to evaluate my own capabilities and use that to fine tune the three power levels. For low level I have 110 watts all in by 160 watts with 15% acceleration. Medium is 130 watts all in by 160 watts with 20% acceleration and high is 280 watts all in by 150 watts. I regularly climb 30 miles up to the peak of my 60 mile ride with 4300 feet of climbing and have 50% battery left. Very little is needed on the descent half. I'm 66 inches or 168cm tall with long legs for a 74cm saddle height and ride a small size. I've used the stock 10-44 and a 10-36 cassette. I like the 10-36 a little better, but it all depends on the exact nature of the terrain you're riding. If I have to add power on the descent to stay near the max assist speed, the 10-36 with 12-13 sprockets is handy. No complaints about the Rival drivetrain.
Hi I'm close to You as age 70th but far away for weight being 75kg [or 165 pounds] even if globally not overweight as I'm178 cm tall or 5,83ft ...till today after about 3 months with Rouvide I rode for 2.300 km [ abt 1400mls] and the final setup for the assistance is Breeze 100/110 watt at 30%-River 180/170 watt at 40%-Rocket 280/150 at 50%
I'm leaving in North Italy close to Como lake and my usual ride are always covering distance in between 80-120 km [50-75 mls] and 1500-2000 mt elevation gain[4900-6500ft]
Here enclose my last ride on the road of Giro d'Italia which I close with 50% of battery still free : https://www.relive.cc/view/vXOnn7zVw5O
Very much happy for Rouvida's performance
I'm recently retired after 45 years in the bike business, mostly as a mechanic and have assembled and serviced a lot of Cervelos. Their geometry and mechanical design--cable routing, component fit--is among the absolute best.
Wondering if this thread might awaken.
I've started contemplating a switch from a TQ HPRR50 to the Fazua Ride 60. It's my particular age (upper70s) and health (angina) that are not allowing me to draw the TQs full potential. I can't contribute more than 100W for more than a few seconds, or the angina will shut me down entirely. That becomes an issue with the TQ due to its 200% maximum support, which means I only draw a sustainable 200W from the motor, missing out on the 300W stronger riders can take advantage of. (I've pleaded with TQ to allow a 300% maximum assist, without increasing its 300W output, to no avail).
An associated issue is that I generally pedal at relatively low cadences of 50-70 rpm, mostly around 60, which is not best suited to the TQ.
The Fazua Ride 60 seems to overcome these constraints if I understand its operating parameters correctly. I'd appreciate feedback from users of the Ride 60 on whether a setup such as I might start out with is tenable at 60 rpm.
Breeze: 100W input, 100 or 125W maximum support
River: 100W input, 200 or 250W maximum support
Rocket: 100W input, 350W maximum support, possible short boost to 450W
Dreaming?
Thanks, Rob
Dreaming?
Thanks, Rob
Sorry, have no answers for you but hope you find a solution.
Also sorry you're stuck with that 100W cap on rider power (Pr). Another member recently reported an 80-90W Pr cap for medical reasons.
Just out of curiosity, I'm going to try some coast and hill rides with a 100W Pr cap on my power-sensing 240W Specialized Vado SL 1 and see what that still allows me to do with only 1.8x assist up to the 240W max.
I can't help you with the Ride60. All I can say is that for riders that are limited to 100w rider input, that's what full power e-bikes were made for. Assist% into the 300's. I know that they're not light and nimble like the Rouvida, but it's an option. I just think that chasing a little more with the Fazua is going to end up chasing a little more down the road. Good luck.
Thanks. I'm aware of the trajectory age is likely to take me on. The TQ is still serving me for the time being, but I would welcome something with more leeway. I've had the TQ about 3 years. It's my inability to tap into its full 300W that is shortening its usefulness.
I would expect the Ride 60's 350W and 450W boost would serve my needs for several years. Then consider what's next.
If the Avinox M1 or Maxon Air S motors were to make their way onto road bikes there would be little concern about addressing further rider decline, but that is an unlikely scenario, as such high levels of performance are hardly necessary for mainstream recreational road riding.
