tomjasz
- USA
- City
- Minnesnowta
There's a lot on your handlebars like the compass.
You can buy display that shows all the features such as battery voltage or percent and distance.
I believe those rely on past/current load as a basis and that has its flaws as well, especially when the remaining future use is not equivalent.If you read my past posts on this subject, you'll see that these cheap voltage based, non linear, e-bike battery gauges are a pet peeve of mine.
The displays on many more expensive bikes incorporate the same accurate gauge technology used in electronic devices like smartphones and electric vehicles. How much extra would it cost to use this superior gauge technology in ALL e-bikes?
If you haven't already purchased that 500A Camway gauge, which is way overkill, there is a 50A version available:I have been using this gage for about six months now,.
Prosport 48 Volt Golf Cart Battery Meter-state of Charge Meter https://a.co/d/cuTW9Lp
I'm really liking it but it has the same issue that @6zfshdb mentioned in that it's voltage based, and the needle movement isn't linear.
The needle picks up speed as the battery drains, but the printed scale isn't quite linear either which helps to offset the imbalance.
The half way point is roughly when the needle is in the middle of the "C".
I am in the middle of installing an analog ammeter to go along with it,..
I've also got a digital Watt hour meter, but I'm going to try the analog ammeter first.
That might be all that I need, and I prefer a needle gage.
CAMWAY Battery Monitor 8-120V... https://www.amazon.ca/dp/B088RG27LS?ref=ppx_pop_mob_ap_share
The shunt is much smaller and easier to place in a controller housing.
The downside to these gauges is the cable is shielded with connectors on both ends. It's very difficult to cut & splice which means the slack needs to be coiled and stored somewhere. It also requires a 5/8" hole for the connector to pass through.
Yeah but that was because you weren't happy with the graphic meter's accuracy. I have had one of these that was built into a battery I bought in 2017 (my very first) and it measures to be dead-on-accurate versus a quality voltmeter. All I use is the voltage readout so I don't care about the graphic. Which means for my uses its small and perfect. This thread reminds me I have one more that is unused and I need to figure out how to plug it into my Bullitt, which has a battery built into the bike, along with a charger, and I have no decent voltage readout other than to use the display on the handlebars... and I know that is high by 0.9v (when the charger is disconnected, so iuts even worse when connected).If you read my past posts on this subject, you'll see that these cheap voltage based, non linear, e-bike battery gauges are a pet peeve of mine.
My bad.. I hadn't realized that you guys were planning lunar voyages that require down to the millivolt accuracy.![]()
