WW 52V Battery Issue
Not sure if WW is using the same company here in CA, but when my first battery was damaged in shipping the 'new' battery they sent had blue painters tape over a crack in the case and scratch evidence showed it was used.
Six months later I was curious, so I checked the first battery. At first it seemed dead, display would not come on. I checked w/ a meter and it was live. Close inspection showed one of the plastic, bottom end nubs was damaged. I sanded it a bit, reinstalled and it worked.
It was 52v - near 60% charge.
The odds against two battery's in a row having a bad cell are up there with two damaged in shipping.
What are the odds of two batteries in a row with a bad BMS or having a voltage leak ???
Could this be your charger? Overvoltage damaging a cell? I'd think by now you'd know if that was it.
TPEHAK or evixone would be sources of reliable information, but I assume you resolved the matter.
I’m using the charger WW supplied with the bikes. WW currently doesn’t have replacement 52v batteries and don’t know when they will get any. I was willing to pay full price for them just because the monetary loss on the bikes is far greater than the cost of the batteries. I’m not a fan of rebuilding batteries so that’s not an option either. I’m considering parting the bikes out and just be done with the whole situation.
Dude ship my one of your battery’s and I will fix it for you for cost.
If the battery’s are lower capacity we can replace them with a higher grade.
Send me a PM if your serious.
Another option is to get a new 52v battery with 21700 cells. Drops the wh rating to 780 but I have been using one for a year and it performs very well in fact better for power and range than the stock 840wh 48v my bike came with. Contact [email protected], cost will be around $400 shipped.
I was all aboard, an optimist and 21700 fanboy - until I did the math.
21700's are not an productive option.
Here's the cases and here's the math.
For 21700 'DP' cases:
DP 4C (40 cells capacity) = 14S2P (28 cells usable).
DP 5C (52 cells capacity) = 14S3P (42 cells usable).
DP 7 21700 (70 cells capacity) = 14S4P (56 cells usable) - and don't think that will fit on my bike.
Conclusion: Reention DP cases are physically incapable of holding as many of the larger 21700's as smaller 18650s.
Example:
DP 6 21700 (same capacity as DP 5C) holds up to 52 21700 cells = 14S3P (42 cells usable @ 52v).
21700 @ 5000mA ea. = Max 15A.
DP 6 18650 holds up to 70 cells = 14S5P (70 cells usable @ 52v)
18650 @ 3200mA ea. = Max 16A.
At this point - munching on crow feathers - I went into denial. 'Who cares 21700's take up more room than 18650's? I can live with less range. It's a good trade-off for less weight', I rationalized.
So (utterly biased) and full of irrational exuberance I set out to prove then conclusion I started with (before gathering facts) was valid.
Predictably I failed.
5000mA 21700 = 70gms.
3200mA 18650 = 40gms.
14S3P = 42 21700 cells, weighing 2940gms w/ 15A
14S5P = 56 18650 cells, weighing 2800gms w/ 16A
Stubbornly I thought: 21700's in a shrink wrap pack will have better figures.
Again I was wrong.
21700 (5000mA) 14S4P = 3920gms w/ 20A
18650 (3200mA) 14S7P = 3920gms w/ 22.4A
The 21700 numbers don't add up to any improvements I want.
Fn'F
A-grade 18650 cells would be 45g or 47g in some cases.
If there is anything we can do to help, don’t hesitate to reach out.
JRA that extra snap you’re referring to is the increase in volts from 48 to 52 Not the battery type in most instances.
The energy density of the 21700 is only marginally better than the energy density of the 18650 cells (about 5% I think).
As a result, space / Capacity wise, they will only be beneficial if they allow a better occupation of the space.
They can also be beneficial for batteries that need to provide high continuous amps.
Are you getting any new 52V batteries back in stock?
I actually have both 48v, 720wh, and 52v, 780wh, 21700 batteries and started off with the stock 840wh 18650. Both are snappier and have better range than stock. YMMV
I was kinda comparing apples to apples.
Example #1: I started off making 52v battery packs using Sanyo GA 18650 batteries that have a rating of 3.45ahr and a discharge rate of 10a.
Example #2: For the last couple of years I have been using Samsung 50E 21700 batteries rated at 5ahr and 9.8a discharge.
Both using identical Daly 30a 14s BMS units.
Both are about the same in performance as far as I can tell. Using the 21700 batterys is the cheaper way to go now that they have become more common and have dropped in price.
Less batteries, lower cost, weight pretty much is a wash.
Load those battery's up with some higher discharge rate cells yeah you will see a difference but it will cost you with the ahr rating which will be less reducing your range.
A few years back I rebuilt up a 72v battery for a guy that had a Kranked bike and we used some high discharge 18650 cells and that thing was a rocket.
Hi all,
Is there anybody out there...? :)
Anyone knows what battery type, and brand I could use to replace the original WattWagons Hydra battery?
Thank you for your response in advance, much appreciated!
Best, Louis
If you have the original battery, you could look for a place that will repack the case with fresh cells. Not sure about Europe but there are many places here in the US that will do this kind of battery rehab work.
Hello, I thank you a lot for your reply, much appreciated!
Hmmm, any thoughts on a 'search term' for Google or Chat I could start with, "bike battery cells replacement", or something alike..?
And, if not a rehab, you know of any brands which would offer complete new batteries that would fit with the Hydra bike..?
Many thanks, and have a great day ahead!
I'm not sure where you are located, but here are a few European companies that to this work:
Prominent examples of European companies that rebuild or recondition e-bike batteries include:
  • Heskon Battery Service Experts (Netherlands): A large, specialized repair company that is a certified partner for many e-bike manufacturers.
  • Doctibike (France): A leading battery repair and reconditioning company that processes thousands of batteries per year. It is also an authorized service center for major brands like BMZ. In partnership with others, it has also developed the EnergYk battery, designed to be 100% repairable.
  • Liofit (Germany): A company that specializes in the repair and recycling of e-bike batteries. It plans to double its capacity with a new facility to meet growing demand.
  • Nowos (Europe-wide): This company partners directly with battery and vehicle original equipment manufacturers (OEMs) to provide high-volume battery repair and maintenance services across Europe.
  • Gouach (France): This company developed a repairable and "refillable" e-bike battery compatible with many brands, showcasing the trend toward more sustainable and repairable products.
  • Enerpower (Germany): A manufacturer that offers e-bike battery services.
Key considerations
Before choosing a battery rebuilding service, keep the following points in mind:
  • Safety and certification: Repairing a battery can affect its safety certification. Reputable companies like Heskon perform extensive stress tests to ensure the battery operates safely after refurbishment and offer warranties. The London Fire Brigade has warned against uncertified batteries and chargers.
  • Cost: Rebuilding is often significantly cheaper than purchasing a new battery. The cost depends on the extent of the damage, but can range from a "partial cell rebuild" for around £105 to a "full cell rebuild" for around £195 (based on a UK example).
  • Sustainability: Companies focused on rebuilding batteries contribute to the circular economy by extending the life of batteries and reducing waste. This aligns with European Union regulations that mandate increased recycling of valuable battery materials like lithium, cobalt, and nickel.
  • Warranty implications: Repairing a battery yourself or through an unauthorized service partner can void its original warranty. Professional companies, however, often offer their own warranty on their repair work.
I'm not sure if this is your battery or not but they are available here in the US:
Shipping to Europe would be costly, if it's even possible, but you might try contacting them. Maybe they could suggest another supplier.
