I’m first going to preface this post by saying this is not a complaint post but merely a request for advice on how to fix an issue with my batteries without having to get Watt Wagons involved. If your only comment is to blame WW please keep it to yourself and out of my post.
I generally tend to not ride in the cold months and have several different e-bikes in my collection. This can result in bikes not being ridden for several months. Out of the two WW 52V batteries I have, one has dropped below the BMS safety limit and will not take a charge. The other I was able to get to take a charge and charged it up to 60%. I’ll give it a full charge later today or tomorrow. Last year I had the same problem where the batteries had drained below the safety cutoff point of the BMS and wouldn’t take a charge. This resulted in both batteries, I have two bikes, being sent back to WW who was able to correct the issue and returned the batteries to me. Upon receiving the batteries I put them back in the bikes and test road them and everything seemed fine. Both batteries were stored out of the bikes and were kept inside my house.
Im using a Grin charger and even using the force charge feature it has the one battery seems to be DOA. The Grin charger display show “Connect Battery”. I’ve used this charger many times on the bikes so I know it works.
Is there any way I can get this one battery to take a charge without having to send it back to WW and what do you guys do to prevent battery drain if the bike sits for an extended period of time? It almost seems like during the cold months I’ll have to keep these two batteries on a trickle charger or something. None of my other bikes have this problem and this time the batteries were not in the bikes so I’m not sure why they drain so quickly.
Any advice will be greatly appreciated.
