It's a Shimano 7 speed hub gear. No loose gears, no derailleur.38T will lose all offset and change your chain line enough to lose some gears.
I already knew the Chainglider. I'm just afraid it will make noise when I'm cycling. I also read that the bicycle chain corrodes the plastic of the Chainglider. You have nice big holes in your bike. Mine are not that big (see photo).I can't seem to find it... But there is a modular plastic chain guard out there. I think it was a Dutch company, but not certain. Try a deep Google search.
Depending on your frame you may be able to run the cables in the frame. Mine has large diameter aluminum tubes and I did it without soldering or issue.
Edit: I think I found it...
Chainguard CHAINGLIDER 350 - Hebie. Since 1868 made in Bielefeld, Germany.
Chainguards made in Bielefeld, Germany. Our innovative and high quality products solve any problems with dirt. Inform yourself here.www.hebie.de
Cog is already flipped so thats it sticks outside.@Gionnirocket, Brilliant! That is perfect for him. It is easier to swap the cog than to change the ring. It keeps the chain line. You can also bring the line in or out at the rear by flipping the cog.
Well these kits require some compromise.I already knew the Chainglider. I'm just afraid it will make noise when I'm cycling. I also read that the bicycle chain corrodes the plastic of the Chainglider. You have nice big holes in your bike. Mine are not that big (see photo).
Even if the Bafang's main cable could pass through, the problem is the thickening of the cable's end; the piece that has to be connected in the other part of the cable. Those pieces go exactly in the middle of the frame's down tube.
P.S. The Chainglider's system is almost like the diy trick with the flexible plastic irrigation or electrical flex wire harness tubing posted by PedalUma![]()
Actually I like it. Is it for children or adults? What is it called in the US?You will laugh at this HD. You would never see this in the Netherlands. See the leather tassels? If you like it I will show you another motor system with a throttle where I chopped the fat connector to go thru frame. I like your bike. Gazelle - Classic.
Yeah, you might be right about the compromise.Well these kits require some compromise.
As for the Chainglider I would think that a wax based lube would be safe... Especially if you wipe off all the solvent after application.
As for the holes... You have two choices.
Enlarge them to pass the connection head or cut and solder. If your close to getting the connection head to pass, I'd opt to enlarge... How are your soldering skills?
Thanks I'll keep that in mind. What is dry lube? Even Google translation has problems with it.Put the chain in a plastic jar with laundry soap and water. Shake for five minutes. Rinse. Dry. Then place the chain in a plastic jar with alcohol or acetone. Shake for five minutes. Rinse and dry. Then use this dry lube. It is safe with plastics because it is not petroleum.
I believe it's 8 wires... Shouldn't be too tedious.Yeah, you might be right about the compromise.
I think cutting and soldering is the best solution. I will think about it. Soldering is no problem at all.
First put a large heat shrink tube to one side away from the action. Each wire gets soldered and the union covered with small heat shrink. Four go one way and four the other. Then slide the larger tube over them and shrink it.have a thin bundle
I think y'all chain crazy.I use PedalUma's method of putting the chain in a jar I use ragu jar shake it up with dawn soap rinse dry and transfer chain in another jar filled with Mobil Oil this time. Shake it up again until color of oil will change from amber to greyish.
This is called wet lube, dry lube never tried.
I like my gold chains naked.
Regardless the chainline will move out 15-20mm. Sorry this old brain can’t remember the exact measurement. That said, why 38T? Lots of inclines? In my limited experience 42T is a BBSxx sweet spot.It's a Shimano 7 speed hub gear. No loose gears, no derailleur.
I get that. When I was doing support there were, how can I describe it.. secrets? Hard earned l3ssons that I didn’t answer directly rather pointed to the information for the fella to sort and learn their own lessons. Maybe that sounds harsh or ego centric to some but when it’s your bread a butter…@tomjasz, It is a single speed chain to a 7-speed Nexus IGH. I do stuff to bikes that is somewhat like what a magician does. I am not going to just give away all my hard earned tricks. Here are a couple more Bafang builds. The first is an HD, the second an SO2, through frame. Bafang builds are rare for me.
