flymeaway
Hi,
I did a lot of research on the (many) ebike company's, and the various frame types and motor/control/battery component configurations offered. I wanted two bikes that would ride closer to a road bike on asphalt but could handle the gravel back roads of New Hampshire. I also wanted a bike that placed the battery lower on the frame and integrated into the frame as much as possible. We (wife on the Cross) took the bikes out for a 20 mile ride over fairly hilly terrain and I was immediately impressed with both bikes abilities. Hills...what hills?? Incredible!!!
There is one very noticeable difference between the Carbon and the Cross and I suspect it has something to do with adjusting the torque sensor. I've ridden both and the Carbon is noticeably more responsive to lower torque levels. The Cross won't kick into pedal assist until a significantly greater force is put on the chain. If anyone can point to a manual that describes adjusting the sensor I'd appreciate it. The torque setting on the Carbon is much better.....hopefully it's a matter of adjustment on the Cross.
On the ride, in hilly terrain, I had the controller set on Eco, Standard, or Throttle (even though I never used the throttle) and completed the ride with 4 bars = 40-60% reserve. With a little more experience I believe I could probably use the assist more wisely and 50 miles seems like a doable ride. I found the Carbon to be easy to ride with no assist on the flats.
Oh...I forgot to mention the bikes are a solid 10 aesthetically.
Court J - Southwest New Hampshire.
