Did you also loosen the four faceplate bolts that hold the handlebar?HI
I would like to raise the handlebars slightly, I have loosened all the bolts but nothing moves, have I missed something?
I'm having the same issues with my SuperchargerHI
All what bolts ? There's 2 types of Bike stems or steering tubes . Quill and thread less. If you are referring the stem that holds the handle bars being adjustable up or down You most likely have to loosen the bolts more . I assume it's one or 2 side bolts ?? If you are speaking of a standard stem . What's your manual say?? It's more then likely the bolts of which there appear to be 2 of. One on each side . Need to be loosened until the thing moves . It also appears to be a Quill stem . SO you'd need to loosen that center bolt . The one that appears to have a small rubber cover over it . Once you do that the stem should raise or lower . Loosen it all the way .HI
Why would you loosen the faceplate bolts ? Not following that idea . It appears to be a Quill steering tube stem. He should be able to loosen that middle bolt until it literally would fall out if he turned the bike upside down . Has nothing to do with handlebar adjustmentsDid you also loosen the four faceplate bolts that hold the handlebar?
Zeeker: It is not very smart to make general comments on e-bikes you are not familiar with. Riese & Muller e-bikes come with a lot of unusual parts and solutions. That's why people like @JVBulman who specialize in R&M are competent here.Why would you loosen the faceplate bolts ? Not following that idea . It appears to be a Quill steering tube stem. He should be able to loosen that middle bolt until it literally would fall out if he turned the bike upside down . Has nothing to do with handlebar adjustments
				 electricbikereview.com
				Curious as to why it didn't work . While I don't own the bike . Mechanics are what they are . I would assume the 4 Torx heads need to be loosened almost to out. The reason he doesn't suggest full removal , they are hard to line up . As they hold that whole stem and riser in place . With that set up you most likely have to juggle it a little and find the balance point to lift the stem up . Then tight the bolts in step 2 just enough to hold it in place . Tighten the Torx screws to torque first . Then go back and torque down step 2 bolts . The bottom one first.The above thread shows the same handlebar stem arrangement that I have on my Supercharger
Handlebar adjustments on Nevo 3
Hi. I'm new to the forum and to e-biking. Have had my new Nevo 3 for a few weeks and I love it. I've ridden quite a bit, even though it's pretty nippy in Upstate NY. I have a couple of questions and hoping someone can help me out. 1. I find the published R&M manuals lacking in detail. Can...electricbikereview.com
Yeah I know . But nobody seems to be answering the guy . After looking at actual pictures in the other thread, where you can see the set up . It's rather obvious how it's set up. My previous answer was going off a website drawing that didn't show much at all . Also when I read the thread he posted . Those guys there are confusing stem bolts with handlebar bolts . The manual that was posted there isn't what the guy from R&M told our OP .Zeeker: It is not very smart to make general comments on e-bikes you are not familiar with. Riese & Muller e-bikes come with a lot of unusual parts and solutions. That's why people like @JVBulman who specialize in R&M are competent here.
Once all the bolts are loose, you often need to grab the bars and give them a firm jerk/twist to free it all up. You don't need to remove the bolts entirely.There is no manual specific to the Supercharger.
I received the below instructions from the service manager at the Riese & Muller dealer that I purchased my bike from.
The process is essentially this:
#1 First, make sure there is enough slack in all of the cables and wiring so that once the stem is lifted, there are no stretched or pinched cables. You may have to cut a couple zip ties to complete this step.
#2 Loosen the 2 large bolts on the side of the stem (these run laterally from left to right, if you are sitting on the bike and looking down at the stem). These don't need to be removed all the way, but some people might prefer to remove them all the way just so that there is as little friction as possible when going to move the stem.
#3 This is part that isn't so intuitive--you need to loosen the 4 stem clamp bolts. These are either T20 or T25 head bolts. These do not need to be removed all the way--in fact I would recommend against it as it is hard to handle. Once you have these fairly loose, the stem should easily move up into your desired position.
I didn't have success with this procedure, although in step #2 I did not remove the large bolts all the way. My next attempt will be removing the 2 large side bolts all the way.
Thanks, I'll remember to do thatOnce all the bolts are loose, you often need to grab the bars and give them a firm jerk/twist to free it all up. You don't need to remove the bolts entirely.
Yep, that's my experience.Thanks, I'll remember to do that
