ThatDudeInAK
Hey everyone! Before I go on asking questions, I'd like to say thanks to everyone on this forum. Lurking around has really helped me in my e-bike build!
Ok, I finished my build about 2 weeks ago and already have over 130 commute miles on it. Over the last two weeks I have been troubleshooting things here and there but there is one issue I can't seem to figure out.
When pedaling at higher speeds (20+ mph) I am getting a vibration that can be felt through the pedals. It seems to be more noticeable at higher speeds when I am in a higher gear. If I stop peddling and hammer the throttle the vibration is not there, so it seems to only be occurring under the force of me actually peddling.
I initially had issues securing the motor to the bottom bracket but I bought a bbs02 instillation wrench from lunacycle and re-installed the motor. During the re-install I ground down the bottom bracket a bit to insure the tooth plate had a clean and flat surface to bite into. I torqued down the lock nut as much as I could and I used blue threadlocker on it as well as the secondary locknut cap.
I just got done with a 29 mile commute and the motor didn't budge at all. But... I am still getting a vibration through the pedals when in a high gear going 20mph+. I have searched around and found several possible explanations but nothing conclusive. The two below being the most likely in my mind.
1. The chain is offset when in a high gear and causes vibrations at high speeds.
2. The drive shaft of the motor is moving vertically within the bottom bracket when applying force to the peddles.
Has anyone else experienced this? Is it considered "normal" or was there a way to fix it?
