I was thinking KT-22a for the 'City, but if you're happy with that controller, why mess with it? That
Lectric sounds like a much more worthwhile project. When you get that bike done and sorted out, THEN you can see if the RAD is worth changing. I've been riding the KT conversions since 2016, consider myself totally spoiled. Any more I just plan on converting any hub drive to KT.
Just briefly, one of the biggest KT advantages is that you can switch it over to power assist.
No more speed based PAS levels. You can set an amount of assist you want in PAS 1 so the bike is easily managed at speeds under 8-10 mph. Even 6 mph. Then, as you need more assist (IF you need more assist), you switch to a higher PAS level.
The difficult part of these KT conversions isn't going to require board level soldering ever. It's more about trying to plug a male plug into another male plug. There's no more than 3 wires involved as a rule, so the easiest way is to just splice the right connector on to one side or the other. Hardest part here is figuring out/confirming which one of the 3 is positive, negative, and signal wires on both sides. That's necessary because all of the colors on both sides can be close, but there is NO universal color guide, so confirming what you have is a good plan.
The motor connectors, with 9 wires internally are the most difficult. Hopefully yours is using a standard Bafang connector and that won't be3 any trouble at all.
I am NOT a fan of Electro bike world. They misguide as many people as they help in my opinion.
You can source KT-22a controllers from Amazon. As mentioned, you want to match that motor connection if at all possible. I prefer the controllers with the waterproof connectors (WP). They make for a MUCH tidier install than the rat's nest you end up with controllers where all the connections are made near the controller. That's something Electro Bike World won't tell you as all they stock are the rat's nest type.
Here's an example of the rat's nest type
Amazon.com : EBike Conversion Controller, 22A 9Tube 36/48V KT22A All Normal Heads Rectangular Controller Electric Bicycle Controller, EBike Controller : Sports & Outdoors
www.amazon.com
Another:
Amazon.com : KUNTENG Controller, 36V/48V 500W/750W E-Bike Electric brushless Controller, Square Wave 22A Controller : Sports & Outdoors
www.amazon.com
And the preferred WP controller using waterproof connectors:
Last, a link to a site that shows a few of the available options when talking KT. There's nothing "standard" to this!
Smarter Shopping, Better Living! Aliexpress.com
www.aliexpress.com
