Has anyone seen instructions for splitting the frame when replacing the belt on a Charger3?
Can't find anything anywhere on this.
On an initial look it appears that the frame split is accomplished via the two large black ( 2 on each side) Torx screws normally used to loosen the wheel when adjusting the belt tension. I assume if these are removed or loosened (further than adjusting) the frame can be split to slide the belt in.
Comments appreciated.
