Eucrider
- United Kingdom
I can't see a review discussion post for this bike so thought I'd start one
Specs - 48v 17ah (upgradable to 25ah and 1000watt ( don't think it gives the full 1000watt but close )
I have the Shengmilo mx03 it's an excellent bike if you know what you want it for, I did 29 miles with more than 60%battery left this was on pas2 mainly flat with some short hills , hills are no problem if you switch to biggest cog and choose the right assist(check the Relive link)
I checked the next day on pas3 same route and had 30% battery left ,
I went out again 2 days after and thought I'd give the motor a test (hills) I got 27 miles until battery depleted but I did go up some rather steep hills and had to work on the steepest climbs but I did stay in the saddle ,
Overall I'm happy with the bike for getting out and about if you want to climb mountains get a mid drive motor ,I pedal in manual mode meaning I use half energy and it assists when needed and if I go over 16mph in pas2 the current fluctuates from 2-1 on the display to conserve battery( I usually ride in 2/3 pas but found 2 is the best otherwise I'll miss the scenery,
Also @Jenny Mao can also provide the new 48v 25ah battery which fits which I might purchase later on I think it uses Samsung 5000 cells so should see good range and power
Any questions or mods anyone has done good or bad is welcome
