I bought a 2021 Vado SL 4.0 EQ and see the new models come with either the TCU or TCD-2. I’m wondering if anyone has been able to get a specialized dealer to retrofit an older model with one of these new displays?
"A little bad news? It is not available today".
That's really fine! (models 530, 830, and 1030+ do even not require the Ebike Field to connect to Spec e-bikes. That's because these models can see the e-bike as a single large Sensor).I use ebike field app on Garmin Edge 1000.
What is the difference between "Battery" and "LEV Battery"?I use ebike field app on Garmin Edge 1000.
Battery is the GPS computer battery level. LEV Battery is the e-bike battery (Light Electric Vehicle).What is the difference between "Battery" and "LEV Battery"?
Thanks. I'm never concerned about my Edge's battery level so never thought to dedicate a field to it. Also, one advantage of the TCU is for monitoring a number of stats (now including estimated range) without having to clutter the bars with GPS units and/or a smartphone. I know how you like a "fully equipped" cockpit but I'm actually looking forward to doing some "unwired", unrecorded rides where I don't tend to fixate on the numbers on the displays in front of me.Battery is the GPS computer battery level. LEV Battery is the e-bike battery (Light Electric Vehicle).
Doug: I carry the BLEvo smartphone running in my jersey's back pocket during my Vado SL rides. The amount and format of stats beats anything Specialized can offer with the Mastermind TCU.Thanks. I'm never concerned about my Edge's battery level so never thought to dedicate a field to it. Also, one advantage of the TCU is for monitoring a number of stats (now including estimated range) without having to clutter the bars with GPS units and/or a smartphone. I know how you like a "fully equipped" cockpit but I'm actually looking forward to doing some "unwired", unrecorded rides where I don't tend to fixate on the numbers on the displays in front of me.The TCU is out of my line of sight so I'd only look at it if I really needed to know something.
On the Edge 1000, the number and contents of data fields is configurable. In the past, the battery level of the GPS has been an issue on long rides approaching 100 km. I have noticed that the GPS battery level decreases more slowly when operating with the Vado SL compared to previous bikes with conventional speed and cadence sensors. I normally ride with the map screen (Open Cycle Map) on the GPS and flick to the data screen only as needed, so I don’t fixate on the numbers either.Thanks. I'm never concerned about my Edge's battery level so never thought to dedicate a field to it. Also, one advantage of the TCU is for monitoring a number of stats (now including estimated range) without having to clutter the bars with GPS units and/or a smartphone. I know how you like a "fully equipped" cockpit but I'm actually looking forward to doing some "unwired", unrecorded rides where I don't tend to fixate on the numbers on the displays in front of me.The TCU is out of my line of sight so I'd only look at it if I really needed to know something.
I don't want to turn this into a Garmin thread, but I had some issues with my Edge 1000 on my 2020 Vado 4.0 when using the Vado's speed sensor. My activities are set to auto-pause and resume when I'm stopped, but as I was riding the Vado about once a minute or so the Edge would do an auto-pause followed immediately by a resume and the beeping was driving me nuts. The only thing I could conclude was that the signal was not being sent at a consistent rate or something and the Edge would think that I had actually stopped moving. I disconnected from that sensor and it started working normally again. If yours works on your SL, maybe it will work with my new SL and Edge (which is now a 1030+).On the Edge 1000, the number and contents of data fields is configurable. In the past, the battery level of the GPS has been an issue on long rides approaching 100 km. I have noticed that the GPS battery level decreases more slowly when operating with the Vado SL compared to previous bikes with conventional speed and cadence sensors. I normally ride with the map screen (Open Cycle Map) on the GPS and flick to the data screen only as needed, so I don’t fixate on the numbers either.
I think it was more than that, and besides it works perfectly well on my other bikes with standard ANT+ speed sensors.You can customise the speed at which the auto pause feature kicks in. I had to reduce the speed threshold on my non-ebike to cater for my slow speed uphill.
Cool! I'm a big FulGazzer but if I were ever to record one I'd have to use my SL or else it wouldn't be fast enough for all the elite riders on there. But I hope you don't use your SL on a trainer to ride routes virtually.I just checked my Garmin and Auto-Pause is off and most likely has been off the whole time since I got my Vado SL. I can check how it behaves when on but it’s a bit late here to try now. I had set it to off as I have filmed a few rides for FulGaz virtual cycling app and they need it off to sync the GPS and GoPro files. The last couple of rides I filmed in the Margaret River area were done with the Vado SL, but they haven’t been published on FulGaz yet.
Guaranteed.maybe it will work with my new SL and Edge (which is now a 1030+).
What does that last comment refer to? What "standard fields?" Anywhere in any Garmin screen or an e-bike screen?Guaranteed.
- Disable the Fake Channel
- Connect Vado SL (E-Bike) as a sensor
- Don't connect any other sensors (Power, Cadence...)
- Use standard Data Fields.
Standard Data Fields as opposed to specialized Data Fields such as E-Bike Field (that you download from the Garmin IQ).What does that last comment refer to? What "standard fields?" Anywhere in any Garmin screen or an e-bike screen?
Before my ride I could not pair my 1030+ to my Creo. After the ride I found that I had two sensors with the same NUMERIC but different icons (cadence icon and a barbell icon). I deleted those and then found an "e-bike sensor" and did that. I guess I should head back down and see what fields are now available.Standard Data Fields as opposed to specialized Data Fields such as E-Bike Field (that you download from the Garmin IQ).
For instance: Speed, Distance, Ride Time, LEV Battery, LEV Travel Mode, LEV Range, Time of Day, etc. are standard Garmin Edge Data Fields.
