Shel-done
- USA
- City
- PNW
Hi EBR forum goers,
Creating a thread to document my upcoming ebike conversion project. I have high hopes for this build after returning a pre-built ebike that didn't meet my expectations.
My primary use-case for this bike will be commuting to work at minimum 3 days a week (approx. 70 miles per week), while also riding to/from the grocery store and running random errands (maybe 100ish miles per week average). Commute miles will not vary based on weather - rain or shine I'll be commuting via bike.
Here is a quick list of my requirements:
.......Enter a DIY ebike project, starting with a Priority Continuum Onyx (should be delivered tomorrow). This bike checks a lot of the boxes above while hitting a competitive price point of $1300.
I'm still mapping out my conversion parts but it will likely be the Shengyi SX1 w/Grin V4 Baserunner. Will post updates as things arrive and I get to building.
- Belt drive - it rains a lot here and the amount of road grime picked up by chains makes maintenance more of a chore
- Internally geared hub - along the same lines of a minimal maintenance approach, needs a high enough ratio/range for hills
- Integrated lights - charging multiple separate batteries is not something I desire on a bike with a 7-10+ lbs battery already
- Hub motor - simplicity, again, with some redundancy from the drivetrain
- Brakes - hydraulic only for the reliability and low maintenance
- Medium battery capacity >48v - no need for 20+ ah with the miles I'll be riding. Anything in the 14-19ah range that is narrow enough for a frame bag. 48 volts should provide enough speed
- Reasonable overall bike weight - I store my bike on a wall hanger due to space constraints, need it <45lbs without battery
- Rear rack w/light mount - will use a pannier for commuting and have an integrated taillight on the rack for rearmost positioning
- Fenders - there are more rainy days than sunny here, this is a must
- Classic design - having owned several steel bikes (steel is real) I prefer the standard straight tube/open triangle frame design
- Display - minimal and unobtrusive. I'm not a fan of big screens on bikes and not convinced there is a tangible value add from color/large screen real estate
