ThanksSolar, car inverter (an adapter won't work), portable generator are choices. If you never intend to go into a town, that's about your choice. If you go through little towns, charge at the coffee shop, parks with shelters and electrical outlets, or library. Too many underestimate just how much power it takes to charge a battery pack in a timely manner. All electricity is not the same.
ThanksI am interested in this too and was thinking @Solarcabin may have some valuable input on this topic.
Welcome to EBR PerrySelf.
Have any of you found a way to charge your bike when away from an electrical outlet? Car adapter? Portable charger?
Some panels are higher watt in a smaller footprint. For a portable system you probably want flexible panels and at least 200 watts.It does greatly, thank you. I was thinking of solar panels on a cargo trailer roof and two batteries per bike, one charging during the day while using the other.
I have seen that some RVrs refer to using the Jackery brand of self contained panels etc. Is there much reason either way to steer toward that system or away from it?
If you are building your own system I would go with 24 volt flexible panels. Less space for more watts.Ah. That makes sense.
So, how about 400w of panels or more and a breaker type switch between bike battery charging leg of system and internal storage leg of the system?
How much area of flat panel for 400 or more?
We would never use a generator even into the evening if it would disturb others but I'm glad you mentioned those small Honda units. We better get one to supplement solar panals - this is ebiking man, no price is too expensive.When I ordered my pickup, I chose a camping option which included a 1200 watt inverter. I used it for a year to charge two bike batteries while camping. It required leaving the truck idling for an extended period of time to get a full charge. Rather than waste that much gas, I bought a tiny 750 watt Honda generator. It runs all night on 2 quarts of gas and it's so quiet, it can barely be heard 50' away. It will charge 2 batteries with enough juice left over for some campsite lighting.
I thought about solar but it won't work to charge batteries overnight. It would be fine for camping when you stay in one place for a few days. That way, you could charge spare batteries during the day while you're out riding. We rarely stay more than 2 nights at the same camp so it wouldn't be practical for us.
The plan that works best for us is to use the generator to recharge overnight and top off the batteries with the inverter while we drive to the next camp.
We never had any complaints when running the little Honda at night and we certainly wouldn't have if it was likely to annoy someone. Most of the places we camp are pretty remote though with few other campers around.We would never use a generator even into the evening if it would disturb others but I'm glad you mentioned those small Honda units. We better get one to supplement solar panals - this is ebiking man, no price is too expensive.![]()
www.jackery.com
Thank you, I'll start looking at those and decide which one will fit our needs best.We never had any complaints when running the little Honda at night and we certainly wouldn't have if it was likely to annoy someone. Most of the places we camp are pretty remote though with few other campers around.
Unfortunately, our small Honda 750 watt generator has long since been discontinued. The smallest Honda makes now is the EU1000i
Honda EU1000T1AG EU1000i - 900 Watt Portable Inverter Generator w/ CO-MINDER™ CARB
The Honda EU1000i - 900 Watt Portable Inverter Generator w/ CO-MINDER™ (CARB) EU1000T1AG has been discontinued. Check out Expert's recommended alternatives for another top portable generators gas inverter generator.www.electricgeneratorsdirect.com
It's spendy and nowhere near as quiet.
I did see someone last season with this 2000 watt model from Wen:
WEN Super Quiet 2000-Watt Gas-Powered Portable Inverter Generator with Fuel Shut Off CARB Compliant 56203i - The Home Depot
The WEN 2,000-Watt Inverter Generator provides clean energy, free of voltage spikes and drops, without all the noise of a regular generator. Produce up to 2000 surge watts and 1700 rated watts of power.www.homedepot.com
It produces twice the power at half the cost of the Honda model above. It was only slightly louder than our little Honda 750.
I also met a couple last year at a camp that used a solar power station to charge their two e-bike batteries. I forget the model but it was similar to this Jackery unit:
Jackery Solar Generator 1000
The Solar Generator 1000 converts sun rays into portable power for home & outdoor use. It consists of Explorer 1000 + 2 x SolarSaga 100W. Ideal for versatility.www.jackery.com
It has it's own internal battery that is charged via solar panels during the day and then used to charge the e-bike batteries overnight. They said the unit was expensive but considerably cheaper than buying extra bike batteries.
https://www.goalzero.com/products/g...7_38742776512681&nb_ppi=&nb_placement=&nb_si={sourceid}&nb_li_ms=&nb_lp_ms=&nb_fii=&nb_ap=&nb_mt=&gclid=CjwKCAjwvNaYBhA3EiwACgndgkTm5VMX1AvIRPsuggJumGJVhjX_mbyTm1LlRc1RDdYD5jkDKZbEDBoCW9kQAvD_BwEHave any of you found a way to charge your bike when away from an electrical outlet? Car adapter? Portable charger?
Wouldn't it take a crazy long period of sunshine to recharge a dead battery with a solar array like that?Renogy has a good setup of portable, flexible panels and multi-input/output battery banks. I have a Rad Runner Plus, a Burley "Flat Trailer", and the 500w Renogy battery bank. I have the 4-panel foldable kit, and I'm waiting to get the 200W Flex panel for my trailer. I'm slowly acquiring equipment from the same firm. It ought to be a cool kit!
